Cases What are the holes for? :)
Discussion in 'Hardware' started by icutebluezone, 21 Sep 2009.
  1. icutebluezone
    icutebluezone The meaning of life is to MOD
    6 Aug 2007
    Hi all.
    Just a little Q? Any one no what these 4 holes are for? on sum pics on the net the case has them but on other photos the case hasnt. I have the case and its got them.
    They are not normal mobo screws as you can see the mobo holes are a differant style.
    :eyebrow:
    Thanks
  2. Slizza
    Slizza beautiful to demons
    23 Apr 2009
    Glory holes?
  3. Krikkit
    21 Jan 2003
    Probably just something from the manufacturing process.
  4. icutebluezone
    6 Aug 2007
    LOL. nice one. :D
  5. Zero_UK
    Zero_UK What's a Dremel?
    12 Aug 2008
    There meant to confuse you!
  6. icutebluezone
    6 Aug 2007
    Forgot to say the case is a Silverstone KL-02
  7. capnPedro
    11 Apr 2007
    Don't some Xeon heatsinks screw into the case as well as mobo?
  8. icutebluezone
    6 Aug 2007
    mmm was thinking that. Havent 1 of the CPU brands got a long square shaped back plate that goes on the back of the mobo kind of like the hole setup on the case?
    Mite email Silverstone tonight and see if they are any help.
  9. Jipa
    5 Feb 2004
    Do the holes really bother you that much? It's not like you could bolt something in and suddenly turn the case into gold or anything :)
    I bet on the manufacturing process/Xeon mount, but what does it really matter?
  10. icutebluezone
    6 Aug 2007
    Mite it be a place to bolt a SSD or 2.5" hdd? :D
  11. Delphium
    Delphium Eyefinity enabled
    18 Mar 2007
    If it dont fit, then thats what one of these are for x] :dremel:
  12. icutebluezone
    6 Aug 2007
    LOL. yeh.
    lol. nice. I have never had 1.
    this is a photo of the part i was thinking of.
    or a Xeon mount?
  13. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    An early (and little known) attempt at VESA wall mount compatibility for computer cases.
  14. icutebluezone
    6 Aug 2007
    mmmmm. after reading your post Silver51. I started thinking could a lcd moniter bolt into them holes. lol.
  15. icutebluezone
    6 Aug 2007
    Ok got a email from Silverstone. Reply is below:
    Hello Mark,
    Thank you very much for purchasing KL02.
    The motherboard tray with 4 holes is newer version and for some special motherboard and CPU cooler.
    Best Regards
    HQ Support
    SilverStone Technology Co., Ltd.
  16. M7ck
    M7ck Ⓜod Ⓜaster
    28 Mar 2009
    Every day is a school day! :D
  17. icutebluezone
    6 Aug 2007
    Just sent them a reply to ask what special motherboard and CPU cooler use the holes :)
    Maybe they have a top secret mobo and cooler they no of. lol.
  18. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    s603/604 Xeons.
  19. identikit
    identikit Minimodder
    5 Jun 2004
    771 Xeons also 'fit'. I say 'fit' because although the distant between the holes is the same the height of the socket is different. Do NOT mix up 603 and 771 coolers or you'll have some expensive mistakes.
  20. SH4D0WM4NZ
    SH4D0WM4NZ What's a Dremel?
    23 Sep 2009
    I can confirm that they are Mount points for Xeons.
