Windows What burning software do you use?
Discussion in 'Software' started by ////\oo/\\\\, 13 Jan 2004.
  1. ////\oo/\\\\
    ////\oo/\\\\ Minimodder
    16 Oct 2003
    I was looking at getting 'Nero' or 'Easy CD Creator', any suggestions/comments?
  2. Arthur2Sheds
    Arthur2Sheds Jackson
    19 May 2003
    I use Easy CD Creator because it's what came with the burner, but I've heard that Nero is better by leaps and bounds. Never used it, though.
  3. nugget
    nugget What's a Dremel?
    11 Nov 2003
    Use Linux, much better.
  4. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I use Nero Ultra Edition. Never had any problems burning anything I needed to. Plus there have been times when I was backing up software ( :worried: ) that Nero would burn some things that EZCD Creator would not. Plus EZCD Creator didn't recognize my previous burner.
  5. ////\oo/\\\\
    16 Oct 2003
    Does Nero do DVDs as well?
  6. simon w
    simon w What's a Dremel?
    3 Nov 2003
    Yeah, I think so.
    Another Nero user over here.
  7. Atomic
    Atomic Gerwaff
    6 May 2002
    Neroooooo!!!!!!!!!!
  8. herbs
    herbs Nobody but us chickens
    7 May 2001
    You always get one don't you :rolleyes: wtf does linux have to do with burning software other than you can run some on the OS.
    Other than the nickname for Easy CD Creator was (maybe still is) Easy Cd cremator. Nero is a good everyday burning package but you will probably use a few packages in the end.
  9. Murdoc
    Murdoc Gas Mask..ZOMG
    25 Jul 2003
    Nero and clone cd, clone cd if i want to backup and they have used safedisk2
    'doc
  10. a9on87
    a9on87 ...
    2 Nov 2003
    Nero - I tried the latest version not long ago (6) agh its horrible - won't let you burn to the maximum size of the cd and the new graphical menu is really annoying so I went straight back to 5.5
  11. ////\oo/\\\\
    16 Oct 2003
    Well I have decided to get an OEM drive and download the demo version of Nero to begin with and see how it goes, thanks for the comments guys :clap:
  12. ////\oo/\\\\
    16 Oct 2003
    The reason I was looking at Easy CD as an option was that I have used Roxio's Toast on the Mac and found it easy to use and trouble free, it does seem like it may be a different story on the PC from the bit-tech ers comments and reading around elsewhere.
  13. mushky
    mushky gimme snails
    24 Mar 2003
    Nero gets my vote. Unless you are doing lots of backups of copyrighted + protected games.... then it can do pretty much everything you need.
    Easy to use, and at the same time versatile. If you cant figure out all the complex settings to begin with then use the wizard. The help file is really good and can teach you a lot.
    If you want to burn DVDs then really you need version 6 or higher. some of the earlier version 6s would not let you overburn CDs but there are fixes for this easily found with google.
    version 6.3 is the best so far IMO. newest ones arent always the best but in this case i think it is.
    The only downside with nero 6 ultra is the amount of bloatware that comes with it. I personally hate nero express + never use any of the other little things they bundle with it. but the main program Nero Burning Rom is my weapon of choice.
  14. ndtinker
    ndtinker Car Washoholic
    23 Sep 2002
    Nero 6 Ultra and yes it does DVD's. Quite well, infact. There's an addon program called Nero Recode that does some basic DVD authoring duties, but it likes to crash alot on my PC for no apparent reason.
    I also use Alcohol 120%. It's an awesome CD-Image creator and burner.
  15. orb
    orb satisfying.
    23 Dec 2003
    nero here, only cus i want to burn my redhat cds
  16. Hex
    Hex Paul?! Super Moderator
    11 Jan 2002
    I'd say go with Nero if you're used to Toast. It may sound strange, but Nero always seemed closer to Toast than EasyCD did!
    I use Toast on my Mac and Nero & CloneCD on my PC.
  17. ////\oo/\\\\
    16 Oct 2003
    Thanks for all the comments guys, as I said I will demo Nero, but It looks like that is what I will go with.
  18. kenco_uk
    28 Nov 2003
    Never had any bother with Easy CD Creator 6 and the suite of software it offers is very good. I've used it since an early version 4 so am quite used to it. I tried Nero a couple of times and it seemed alright, though.
    Also use Alcohol 120% and other stuff like burnitonce, etc..
  19. psYCHopath
    psYCHopath What's a Dremel?
    25 Dec 2001
    Hi,
    sorry for hijacking your thread ////\oo/\\\\
    since this is almost the same question i want to ask.....might as well ask it here than repost.
    I just want to know what dvd software can i use to convert DVD9 to DVD5 its for my anime stuff.....and YES i have bought the ORIGINAL dvd.
    Just dont want to scratced it, I did screatched it before and became unreadble....in the end i have to purchase the same one again. :waah:
  20. Astrum
    Astrum Dare to dream.
    8 Mar 2002
    I love Alcohol 120%, works very well for me.
