Other What Cable/Adaptors do I need?
Discussion in 'Hardware' started by Razgrad, 28 Nov 2014.
  1. Razgrad
    Razgrad Member
    2 Dec 2010
    HI. I am about to buy the Dell U2415 monitor, that has
    2 HDMI(MHL) connector
    1 Mini DisplayPort
    1 DisplayPort (version 1.2)
    1 DisplayPort out (MST).
    Sadly, My Video card has only :
    Two Dual Link DVI, Mini HDMIStandard Display Connectors.
    I google-d around and found out that I can't use a simple DVI to Display Port cable. It works the other way round, but for DVI to DP it has to go trough a special box , that costs a lot of $$$.
    So I like to keep using my mini HDMI port on the GPU to bring signal to my TV .
    What cable do I need to connect the GPU and the New Monitor ? Is it DVI Male, to HDMI Male, or DVI Female to HDMI Male , or DVI Female to HDMI Female....
    Thank you.
  2. The_Crapman
    The_Crapman Don't phone it's just for fun.
    5 Dec 2011
  3. Razgrad
    Razgrad Member
    2 Dec 2010
    I guess you read my question the wrong way. I want to keep my HDMI output for my TV, and use the DVI output of the GPU for the monitor, that has no DVI Input options.
  4. The_Crapman
    5 Dec 2011
  5. Publ!c Enemy
    Publ!c Enemy or Richard for short
    4 Jul 2010
    Good evening,
    I'd go for what The_Crapman has suggested, might get it a little cheaper on eBay if you wanted.
    Regards, Richard.
  6. The_Crapman
    5 Dec 2011
    Oh god yeh you'd probably get one for 50p on fleabay. Or a dvi to hdmi adapter.
