Got several 6 Gang Extension boxes minus cables and rather than get the wrong type could someone advice with a link to the correct cable for a simple extension?
2.5 3 core PVC flex http://www.ebay.co.uk/itm/White-Fle...317?pt=LH_DefaultDomain_3&hash=item5b01d876b5
That's a life saver, can you provide a link to where I might purchase this essential earth cable for my 6 gang extension box?
Sure, any of the big electrical wholesalers should have it. It's our part number CC400. Getting fittings for it are a bitch though so I recommend exothermic welding for any joints you need to make.
I am concerned that the connection point in both box and the 3 pin plug might be a little small for this cable. Can I get a reducer fitting?
Crimp a terminal on it and reduce down with an appropriate bolt. We could do a welded joint that would go from 400mm² to 2.5mm² I suppose but it would reduce the current handling somewhat.
