Modding What can i do about this??
Discussion in 'Modding' started by LoopyJuice, 24 Feb 2002.
  1. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    I have a CD-RW drive as in sig, but i have a problem. It has a bigass ribbon cable coming out the back connecting to an scsi card in a pci clot at the back, i didn't put this in. It was fitted when the drive was fitted and it is a pain in the ass because it spans across the whole case and looks v untidy and covers a bunch of stuff up on my mobo and it would looka lot better without it. Any ideas on what i can do?? i currently have it folded in half and zip tied but it is still bad :confused: i am gonna order some spiral wrap soon for the rest of thewires but it will look crap with this big lumpa cable in the middle :confused: thanks
  2. GreatOldOne
    GreatOldOne Wannabe Martian
    29 Jan 2002
    Get a longer scsi cable.
    Do the zip tie thing to lessen the cross section, and then route it down the drive cages, along the floor and then upto the scsi card.
    It's that or ditch the drive and get an IDE burner.
  3. Iamgoodyy
    Iamgoodyy What's a Dremel?
    11 Nov 2001
    Or still get a longer one and route it along the panal on the back of the motherboard. If you don't have a hole on the bottom for it, then just take out the trusty dremal and slice yourself a newone.
  4. UnLoadeD
    UnLoadeD What's a Dremel?
    2 Jan 2002
    I would try rerouting, I've heard scsi cables are bad about getting interference when you fold them on themselves.Have you had any burner troubles since you've zip tied them?
  5. LoopyJuice
    24 Jun 2001
    hmm where can i get a longer one? this one is erm... about 24 inches and not long enough to do that
  6. TOPLOADER
    TOPLOADER What's a Dremel?
    14 Jan 2002
    make it into a round cable mate just pull all the wires apart cable tie them at each end then cover with spiral wrap thats what i have done with mine looks neat
  7. LoopyJuice
    24 Jun 2001
    won't it screw up the cable? i know ppl do it with ata/66/100 cables but never heard of scsi ones being done :confused:
  8. tk421
    tk421 Idiot.
    15 Jan 2002
    you can get nice tidy machine-rounded scsi cables now ...
  9. LoopyJuice
    24 Jun 2001
    where from??
  10. tk421
    tk421 Idiot.
    15 Jan 2002
    here.
    or here.
    or even here.
    thats just 3 minutes worth of poking about on hotbot ...im sure you could probably find more, and closer to you ..
    and btw .... the ORB addy in you signature is the wrong one ... right click on the "compare url" and copy shortcut ... the cgi changes it when you click it ...
  11. LoopyJuice
    24 Jun 2001
    thanks man, also ta for pointing out the link, i'll go fix it now
  12. TOPLOADER
    14 Jan 2002
    as i said m8 i hve done mine and it works fine no probs what so ever just go for it mate why buy a round cable when you can do it yourself i cut inbetween the wires with a razorblade just do about 5 or 6 at a time and dont do the cuts next to each other and take your time
  13. LoopyJuice
    24 Jun 2001
    well it is ok at the mo, i realised there were 2 connecters on it, one close to the middle and one on the end and it was on the middle one so i put it on the end one which lengthened it adn i have it folded out of the way, i have just bought a round cable for my hdd so i may aswell buy one for the scsi to keep the look going :)
  14. benje
    benje What's a Dremel?
    4 Feb 2002
    Yeah make sure u match the colour with your IDE rounded cables :)
  15. LoopyJuice
    24 Jun 2001
    hehe i am going for all bloo :) bloo leds, bloo cc and black cc, bloo rounded cables and spray fans bloo maybe :) of paint them with uv stuff ;)
