Disaster What can i do with this....
Discussion in 'Modding' started by Jaguar_Infinity, 26 Oct 2008.
  1. Jaguar_Infinity
    Jaguar_Infinity Just some guy
    8 Oct 2003
    Ok i have an old skool 120mm Delta EHE High flow fan. I got it way back in 2003 for a head to head challenge to make a basic radio controlled hovercraft and this thing got me the win. I have never plugged it into my PC, i know some people do but its tooooo extreme for general desktop use IMO. I mean the thing is rated to draw 36 Watts of power. You shouldn't even use 95% of fan controllers with this thing it pulls so much juice. Its rated at 59Db in noise! all i know is that you do really have to shout over it. Oh and the nice 190CFM of airflow helps (that was the main reason i used it in my project)
    Now the sales pitch is over what can i do with it :confused: I've kept it all these years mainly because in all honesty its an awsom peice of kit, you can feel its a well made bit of kit when you hold it in your hands and it looks like it will cut a finger off if you get too close. I don't want to destroy it because i like it too much. But what do i do with it?
    Ideas?
    Stuart
  2. ModMinded
    ModMinded Are you throwing that away?
    26 Aug 2008
    Since I had no idea what it looked like I found this on youtube...
    http://www.youtube.com/watch?v=11spw-uewHI
    Seems you could use it to make chainsaw/jet sound effects!
    It doesn't seem like anything I'd want in a PC (unless I was entering the Noisiest PC Around competition), but I could imagine using in the shop as a ventilation fan for a homemade paint spray booth, or something similar.
  3. docodine
    docodine killed a guy once
    10 Feb 2007
    How about... putting it into a cone and using it as a personal air conditioner.
  4. Xir
    Xir Modder
    26 Apr 2006
    How about you turn it into a radio-controlled hovercraft?
    :D
  5. Cheapskate
    13 May 2007
    Put it in a case as an emergency cooler. You need a big switch on the front of your case labeled 'TURBO'.
    You could even have little strips of tape on the grill. OR- a little parachute. Or...one of those silk tubes shaped like a person they attach to blowers and put out in front of car dealerships!!!
  6. ModMinded
    26 Aug 2008
    lol...
    Or use it to create special effects for photos?
  7. Cheapskate
    13 May 2007
    Mini stump grinder?
    A freefall wind tunnel for your hamster?(or a hamster grinder)
    Mount it under your desk and use it to cool your nethers?
    Use it to push air through 4 or more stacked 120 X 1 radiators?
  8. stuartwood89
    20 Aug 2008
    I really like this idea. It would be good if you're running high end games and you don't care about noise too much (ie you're wearing headphones or something).
    Or you could put a variable resistor in there and set it to a low current or something (like a fan controller I suppose, but just for that fan).
  9. Pneumonic
    Pneumonic What's a Dremel?
    31 Oct 2008
  10. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    Heres my idea:
    TURBOCHARGED COOLING! Basically what Cheaps said, but with inspiration taken from the automotive sports industry. Have it strapped to the top of your case, with tubing going into the front/side of your case, ready to surge 190CFM of cold air into your case if the temperatures get too high :rock:
    Something like:
  11. Cheapskate
    13 May 2007
    Or label the switch 'PURGE' and use it to dust the system.:D
    Attach it to a footpedal rheostat, so you can 'rev' it. Imagine sitting at a LAN, giving the person next to you a challenging look, and making your computer go "VRooMMM!"
  12. ModMinded
    26 Aug 2008
    :thumb:
    Dude that's my favorite idea right there! (rev-able)
  13. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    i can't think of anything more awesome than an RC hovercraft. do you have any pictures/video of that?
  14. MonkeyTurnip
    MonkeyTurnip What's a Dremel?
    23 Aug 2005
    that is aawsome idea, im going ot buy a 120mm fan just for this
  15. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    Awesome idea, my 4870 shoudl be perfect. :p
  16. kenco_uk
    28 Nov 2003
    And then hit them square in the face with a cloud of dust :)
  17. Cheapskate
    13 May 2007
    :lol: If I could think of a way to make a single blast of smoke, I would have suggested it.
  18. stuartwood89
    20 Aug 2008
    Attach it to the bottom of your case and turn it into a hover-case.
    ...a radio controlled hover-case.
  19. barry99705
    barry99705 sudo rm -Rf /
    20 Apr 2008
    Holy crap!!! That'd blow the side off at full speed!
  20. stuartwood89
    20 Aug 2008
    It would spin around on it's base.
    *edit* And then explode.
