Cases What Case?
Discussion in 'Hardware' started by Eddieboi, 27 Aug 2009.
  1. Eddieboi
    Eddieboi What's a Dremel?
    27 Jun 2009
    A little problem has come up, Im ordering an i7 system for my friend tomorrow, and scan seems to not have either the antec 1200 case nor the HAF 932.
    What alternatives would you lovely bit-tech people recommened around the same pricing and good air cooling performance
  2. Mr. Ducky
    Mr. Ducky What's a Dremel?
    15 Aug 2009
    I have the Haf922 and really like it, if you add the optional 200mm fan to the side, or two 120mm fans, it has the same cooling as the haf932, plus if you read the bit-tech review for the 922, they made quite a few improvements over the 932.
  3. Fazed
    Fazed Minimodder
    5 Jul 2009
    Excuse me in advance for asking a silly question, but if you're looking for the 1200 or HAF932, why not just buy them from another e-tailer???
  4. Eddieboi
    27 Jun 2009
    Just to keep cost down and making it easier to have everything delivered together
  5. Fazed
    Fazed Minimodder
    5 Jul 2009
    Fair enough.
    Lian Li PC-P50B Armorsuit?
    EDIT. Forget that, it's at ebuyer, not Scan!
  6. Jokaz
    Jokaz What's a Dremel?
    24 Apr 2009
    The Lian Li PC-P50B comes with free delivery from ebuyer if cost is an issue
  7. Eddieboi
    27 Jun 2009
    Just a side question any idea why Ebuyer lacks i7 CPU coolers? Or am I just blind and not able to see them lol
  8. Abhorsen
    Abhorsen Minimodder
    10 Apr 2008
    Antec 902? Or not big enough? On scan i believe they have it as the 900-2.
  9. =WBG=cpt_custard
    =WBG=cpt_custard ferret
    29 Jul 2009
    cosmos s all the way here...gone from a 900 to this and i couldnt be happier....well i could but water cooling has to wait a little while lol
  10. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    Don't think there is a specific section for core I7 coolers as most coolers come with brackets for all three mounts so they are all bunched in together.
    Ebuyer has the Antec 1200 in stock and as mentioned above its free delivery. Is it dearer than what scan were asking, if not just order from ebuyer.
  11. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    +1 for the 900. it's a good case to build for people although it does have a lot of holes.
    (My friend's one growls at me. :()
  12. LT.BEECH
    LT.BEECH Minimodder
    23 Apr 2009
    +1 for the cosmos s it's got great cooling and you can add more fans in the future and you can get it off pcworld for £100 and p&p is free:D
  13. CrapBag
    CrapBag Multimodder
    17 Jul 2008
    I've always liked that case but didn't realise you could get it that cheap now.
    I did a quick search for reviews and prices and came accross the CPC review from last year that didn't rate it for cooling, have they changed things to improve it??
    Aforementioned review from CPC
    Abhorsen likes this.
  14. adidan
    25 Mar 2009
    It's collect from store only and you're lucky if you're near a store that has one.
  15. Slizza
    Slizza beautiful to demons
    23 Apr 2009
  16. damienVC
    damienVC What's a Dremel?
    25 Aug 2009
    I'm a 300 fanboy. Mine just lurks in the corner, so black that light just falls into it.
  17. Ending Credits
    4 Jan 2008
    You can get a B-grade Cosmos off of the Coolermaster store for 80 euros.
  18. bigsharn
    bigsharn Officially demotivated
    9 May 2008
    +1, mine's stood next to my Xbox 360 and I'm sure the white's draining from it...
    Dark, evil case...:eeek:
  19. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    CM 690, for price per CFM, even the Antec 300 doesn't come close when you fill all the fan bays, and if your willing to do small mods, the side panel is solid so you could do either a window mod or a massive fan mod...
    http://www.scan.co.uk/product.aspx?ProductId=21651
  20. Rotcrack
    Rotcrack Food Maestro.
    24 Jul 2009
    902!
    Go for the Antec 900-2! You can get it at Scan and is perfect for first builders. Plenty of room and plenty of cooling, you cant go wrong.
