What clocks are people folding at (i7 particular interest :-) )
Discussion in 'bit-tech Folding Team' started by littlepuppi, 2 Sep 2010.
  1. littlepuppi
    littlepuppi Currently playing MWO and loving it
    26 Apr 2009
    Ill kick off
    980x 4.2
    930 4.1
    Am I behind ahead or on curve here....
    Cheers in advance peeps...
  2. AnniGTI_Court
    AnniGTI_Court New Member
    29 Sep 2009
    920 @ 3.55 (Lazy Clock)
  3. narwen
    narwen narwen
    6 Aug 2010
    875k @ 3840
  4. saspro
    saspro IT monkey
    23 Apr 2009
    i7 920 (1) 4GHz
    i7 920 (2) 4GHz
    i7 920 (3) 3.6GHz (C0 so won't go higher in Windows without insane voltage & cooling)
  5. littlepuppi
    26 Apr 2009
    And im not happy with 4.1 on the 930.... Maybe I should go easier on it! :)
    Just ordered 2 gentle typhoons to try and boost the cooling and get it faster...
  6. cian1500ww
    cian1500ww Drunken Irish Dude
    30 Aug 2010
    Q6600 @ 3.4Ghz and an E6550 @ 2.7Ghz
    Hoping to get the E6550 to 3Ghz when the winter comes as it's outside in a garage !!
  7. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    i5 750 @ 3.8 (It point blank refuses to go any higher :()
  8. SpeckleD
    SpeckleD New Member
    23 May 2010
    i7 930 @ 4.2, just purchased, and I am stunned at the points I am hitting running -bigadv.
  9. Paddy4929
    Paddy4929 NangO-Gamer
    24 Apr 2009
    I7 930 @ 3.6 and just the normal SMP as it's only part time folding
  10. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    AMD Phenom X4 9850 Black Edition (Stock Clock)
    I'm also going to be installing in the next couple of weeks a dual-CPU Xeon E5504 (Stock Speed) machine for my first bigadv run, and I'll probably put 1 or 2 GTX260's in there aswell :)
  11. General_Confusion
    General_Confusion Now Where was I?
    3 Jul 2010
    980x @ 4.1 water (it's going to be moved to another board so havent bothered pushing it further)
    860 @ 3.66 air (just used asus's auto-oc function too lazy to see what it will do...)
    920(c0) waiting for the 980x to move to it's new home.. have had it up to 4.2 but takes too much voltage to make it stable.. it runs happy around 3.8..
  12. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
    i7-980X @ 3.6GHz, as although it will fold at 4GHz games crash any higher than 3.6GHz. However, I suspect the crashing problem is actually being caused by my HD 5970, which I'm seriously thinking of retiring soon thanks to its rubbish drivers.
  13. Phalanx
    28 Apr 2010
    Mine's beeg doing fine. I did consider selling it and getting 2 x GTX460's about 3 weeks ago but the prices of the 5970 dropping don't make it worth my while unless someone wants a still-in-warranty 5970 ;)
  14. 1Razor
    1Razor Living life one day at a time....
    24 Apr 2009
    i7 920 @ 3.8
    2*Q9550 @ 3.2 (lazy OC)
    all on air
  15. dark_avenger
    dark_avenger Well-Known Member
    9 Jul 2008
    i7 @ 3.8 was running at 4 but it was running a bit warm for my liking.
  16. Keith_Whi
    Keith_Whi New Member
    6 May 2009
    i7 920 @3.8, as above runs fine at 4.0 but the H50 just don't cut it at that speed.
    Q6600 @ 3.0, on air.
    Q6600 @2.9, on air, this one won't go past that.
    :thumb:
  17. littlepuppi
    26 Apr 2009
    Great to see and hear all the differnt configs people are running.. I am surprised we havent seen any 4.4 's yet (this is what I am aiming for) but it does seem difficult to get it stable enough to fold at that speed..... Even under custom water...
    Thanks for all te feedback so far lads.
  18. rojw13
    rojw13 New Member
    28 May 2010
    i7 875 running at 4Ghz
    i7 860 running at 3.7ghz
  19. Hypnosam
    Hypnosam New Member
    12 Mar 2010
    Stock on my i7 920. Gfx though something in my room started to smell of warm/burning plastic so i stopped folding, and once I stopped folding, the smell stopped. Need to investigate that.
  20. DocJonz
    DocJonz Another CPC refugee .....
    24 Apr 2009
    Mine are currently running at stock speeds due to temps .... what temps do you guys run at with the OC's??
