What color LEDs?
Discussion in 'Modding' started by pizan, 12 Sep 2008.
What color LEDs?
  1. White
    4 vote(s)
    33.3%
  2. Red
    2 vote(s)
    16.7%
  3. Green
    3 vote(s)
    25.0%
  4. Other (not blue)
    3 vote(s)
    25.0%
  1. pizan
    pizan that's n00b-tastic
    25 Apr 2008
    I just got a Danger Den Tower 26 and after kind of figuring out what to do to make a front panel (thanx Cheapskate). I was wondering what everyone feels about what color i should go with. The case is acrylic The mobo tray, top and bottom are black acrylic and the rest is clear. I was originally going to use white, but I'm not sure anymore.
  2. pizan
    25 Apr 2008
    Here is a review of the case with the same color layout i have. They used red in this one.
  3. Akava
    Akava Lurking...
    28 Jul 2007
    Any reason not blue?
    Other than that, green, I've always liked the look of green WC fluid flowing through the tubes, so... yea.
    Ninja edit: Though I recon white might look pretty good in there, just only really in a darked room.
  4. pizan
    25 Apr 2008
    I decided to go with white.
    and not blue bc im just so sick of blue all my cases have had blue. hell one was even blue itself.
  5. mvagusta
    mvagusta Did a skid that went for two weeks.
    24 Dec 2006
    Anything goes with black, so where's the pc gonna be located? Is it for taking to lans, or is it gonna stay in at home? If it's gonna stay at home, then choose a color that goes well with the room/pc desk/surroundings, but there's also my fav option. Use a couple of different color leds in there or just use multicolored leds, so you can switch between colors or even mix colors whenever you get bored of one. If you use red, green & blue leds, you will have 7 different lighting combinations available. You can even add a dimmer to top it off.
    If you had three dimmers hooked up to control each individual color string, then the color combinations are huge, but that's probably going overboard :D
  6. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    I was going to say purple, but white is cool too.
  7. Snafu-X-
    Snafu-X- What's a Dremel?
    27 May 2005
    Amber/Orange is the new blue.....
