what CPU core?
Discussion in 'Hardware' started by 2800@2.5ghz, 10 Jul 2005.
  1. 2800@2.5ghz
    2800@2.5ghz What's a Dremel?
    23 Mar 2005
    right, i'm looking to buy an Athie 3500+ (939) and i know there are various cores out there, but which one is the best, is it the venice core i want?
    (i ask becasue i plan to overclock the s**t out of this processor, so its quite important i get the best core)
  2. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    The Venice 3500+ is by far the best for its speed... I'm a big fan of the 3700+ San Diego, myself. About $50 more for double the cache. (1 MB instead of 512 K)
  3. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    the venice core is the one you want, unless you can stretch to the 3700+ san diego cored chip
  4. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    As the 2 above said :) 3500 venice is the best of the chips, unless you can stretch to a 3700 diego :)
  5. webbyman
    webbyman Hax.
    7 Oct 2004
    a sandiago 3700+ :D or a 3500+ venice... although if you want it more garanteed then find a good 2nd hand clocker :idea:
    ^i can't spell 'garenteed' :(
  6. 2800@2.5ghz
    23 Mar 2005
    neither can i :D
    thanks for the help, will make sure i get the venice core :naughty:
  7. Hamish
    Hamish What's a Dremel?
    25 Nov 2002
    guranteed :p
    oh and toledo for the win ;)
  8. webbyman
    webbyman Hax.
    7 Oct 2004
    :hehe:
    i haven't seen if the toledo clock well or not yet.. :eek: some people brought the old mobile 64's
  9. Hamish
    25 Nov 2002
    mines at 2.6gig atm, havent really pushed it either yet :)
    theres people on Xtreme Systems with X2's at 3gig+ on phase change and 2.8gig ish on water
    only problem with clocking them is quite often one core won't go as far as the other
