Other What currently makes your life awesome?
Discussion in 'General' started by Brooxy, 28 Oct 2009.
  1. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    The sort of floor I'd expect from someone that's been reviewing carpets and kept samples.
    sandys, Isitari, perplekks45 and 4 others like this.
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    I reckon he's sent off for a free sample from every carpet place in the UK.
  3. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Step two of upgrading my workstation is complete. If I wanted to play a game, I could make a RAMdrive and install it and have enough to play it easily. (I may have to test that theory.) Due to someone apparently being told "just get rid of it," I got 256GB of PC3-14900 ECC for$120, which was less than 128 at the prevailing rate. Best believe I jumped on that.
    UE5 takes an awful lot of memory, so I figure this will get me some breathing room. Might could even open a few tabs in Chrome.
    Also, free mechanical keyboard.
  4. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Woah, slow down, mate.
  5. DeadP1xels
    30 Nov 2009
    My laptop has randomly decided it wants to work with my wireless printer… I’ve tried many times before to get this working flawlessly over WIFI and suddenly it does!!
    I usually spend absolutely ages faffing on my phone to organise shipping and collection, this will save me so much time going through eBay over the app.
  6. Gunsmith
    Gunsmith Maximum Win
    23 Sep 2005
    lastnights rick and morty, haven't laughed that hard in ages.
  7. Mister_Tad
    27 Dec 2002
    Update: 250k streams :rock:
  8. Gareth Halfacree
    4 Dec 2007
    Despite having had, effectively, the entire dormer at the old house re-done, there's a leak - showing as a wet patch on the new plaster. Guessing that means we're going to have to have the (pretty massive) window replaced, as the guy we had to look at the problem originally drilled some "drainage holes" that come out inside where the frame is sealed to the sill(!) and there ain't much coming back from that.
    Why is this in the "awesome" thread? Well, I'm trying to look on the bright side these days - and if we do have the window replaced we'll have a nice shiny FENSA certificate to wave at the buyer. Better still, I did my first meter reading since September and it turns out my energy company's estimates are well off: Today, on the 23rd of November, I've used about 6kWh less gas and 270kWh less electricity than they thought I'd used by the 22nd of October. Should mean my next payment not only wipes out the debit I'd built up but puts me a hunnert or so in credit.
    Isitari, Mr_Mistoffelees and IanW like this.
  9. Vault-Tec
    30 Aug 2015
    Fire Stick 4k came in. Ads gone. Sanity restored.
  10. Scroome
    Scroome Modder
    26 Apr 2011
    I have no idea how to post images here, so if it doesn't could someone be kind enough to help this old boy :D[​IMG]
  11. Gunsmith
    23 Sep 2005
    replace the brackets with square brackets [ ]
    Scroome likes this.
  12. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    [img]enterurlhere.jpg[/img]
    Thusly? :p
    Scroome likes this.
  13. Scroome
    Scroome Modder
    26 Apr 2011
    Thanks both :)
    So I need to upload an image somewhere and then link it here?
    There's no ability to just upload?
  14. wolfticket
    19 Apr 2008
    You can upload to your user gallery here then paste the bbcode, but your ymv as to whether that's easier or more convenient than just using imgur or something.
  15. noizdaemon666
    15 Jun 2010
    Yeah if you head into Media, you can upload to your own albums and then when writing your post you can embed from your media, or copy the bbcode and link it directly. Alternatively, use imgur as wolfticket said.
  16. Almightyrastus
    Almightyrastus On the jazz.
    21 Mar 2002
    Go up to the top of the board and click on Media, then Add Media:
    I normally drop my uploads into an album of general stuff, you can create that here:
    Then upload your image using the normal web upload window bits:
    Once uploaded and saved, you'll see the image(s) that you uploaded:
    Select the image and look to the right, just copy and past this option into your post and post like normal:
    There may be faster and easier options, but this has always worked for me.
    perplekks45, Byron C, Scroome and 2 others like this.
  17. Scroome
    Scroome Modder
    26 Apr 2011
  18. Scroome
    Scroome Modder
    26 Apr 2011
    And this is why I love you guys. Always so helpful :D
    Anyways. Here's my new tattoo! :)
    ElThomsono likes this.
  19. Mr_Mistoffelees
    26 Aug 2014
    No pictures...
  20. Scroome
    Scroome Modder
    26 Apr 2011
    That's weird. It shows the image above what I've posted?
