Other What currently makes your life awesome?
Discussion in 'General' started by Brooxy, 28 Oct 2009.
  1. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    Very nice, but I don't believe for a second it's your last...
    perplekks45, adidan and Byron C like this.
  2. Byron C
    Byron C Ripping a line of speed off a sh**-encrusted bog
    12 Apr 2002
    Nice. Could do with a reliable cleanup company right now; my mother's selling up and downsizing, and she's got a ton of stuff to clear...
    adidan likes this.
  3. Weekly_Estimate
    Weekly_Estimate Random bird noises.
    1 Feb 2010
    If only I was closer mate,
  4. Vault-Tec
    30 Aug 2015
    Yup, sadly it is. Mum had fake grass fitted at the end of last year, and I had such a ball ache covering up all of the concrete 5 times I have taken the stand apart and put it in the recycling bin.
  5. adidan
    25 Mar 2009
    We could have done with @Weekly_Estimate 's services when we cleared out the tenants mess.
    Mind you, I quite like going to the tip. :grin:
    Weekly_Estimate likes this.
  6. ModSquid
    ModSquid Multimodder
    16 Apr 2011
    You like the Montana stuff? I tend to go for Kobra but that last finish of yours does indeed look half decent. What do you lacquer it with and is there a matt equivalent?
    Good luck indeed with the new enterprise, sir! But don't you let it interfere with game time now - I've just got a new disk to put Citizen onto and I hope to be seeing you in the Verse, remember? As soon as I get time to install the damn thing...
  7. Weekly_Estimate
    1 Feb 2010
    Thank you! I absolutely do remember! Which I didn’t remember when I sold my gpu which is the only thing I’m now lacking to play in the verse! I’m sure I’ll be back soonish? I’ll keep you updated!
    Bloody_Pete likes this.
  8. Vault-Tec
    30 Aug 2015
    I use Kobra a lot. However, colours depend on how bad the over spray is. I mix and match *a lot* as they are all acrylics.
    I always, but always, use Kobra clear. they do it in flat and gloss.
    But, due to this being all acrylics I have had to work out a method over the years. It is absolutely nothing like the method you would use with 2k, it was all about adapting.
    Firstly, NEVER use panel wipe/thinners etc on it. It will take it clean off, as these paints are in a "nitro" base AKA acetone. Literally melted plastic in acetone. So acetone will take it straight off. Even alcohol will damage it. So, get your part prepped, then clean with hot soapy water. Best degreaser there is.
    I then wipe over everything with 99% iso, and then go around with a tack cloth. Those are cheap.
    Get your primer down. I usually always use etch, as I don't remove all of the old finish unless I have to, but sometimes have to go all the way down to remove a chip or scratch/gouge.
    Then wet sand back the primer, again clean with hot soapy water. Then put your base down. I have never found a gloss acrylic, they are all flat or satin. You will get spitting. The nozzles are crap. So, get one heavy coat down (it is anti sag, and will even off, very clever) then let that set for 24 hours. Then, and this is the biggest and best trick I ever learned on it, brillo pad. Overspray is absolutely atrocious on acrylic. You don't even need to wet sand it, just go over it with a brillo pad every coat. You will hear the sound change from rough to a nice smooth glide, that is when you know it is good. Good thing about brillo pad? soap filled, and that soap removes any grease. Wash it down again in hot soapy water, rinse and repeat. I wet "sanded" mine about 5 times between coats. I wet sanded it properly with P1000 after the first colour coat, to remove all drips and spits. You don't need to go harsh after that.
    You will always need to learn by each can and the nozzle how close to paint. Because if I had done the normal 12" on this? I would have peppered it with dry over spray. So, I had to go in much closer.
    Edit. Don't ever dry sand acrylic. It will just get sticky and gum up the paper. Hence, always wet on acrylic.
    ModSquid likes this.
  9. Vault-Tec
    30 Aug 2015
  10. keef247
    keef247 Yer Da Sells Avon
    11 Aug 2006
    I would say I'm impressed... But you failed to get any of the patio, amateur!
    Does look banging though :naughty:
    On another note... Got myself a 2TB Corsair MP600 Pro XT with the OTT hench heatsink for the price of the same one without the heatsink... Thanks Scan :rock:
  11. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Client event in Paris was a huge success. Most clients buggered off home this morning, the rest is happy without me for the next few days.
    My wife arrived today and now we have until Monday lunchtime to enjoy the city.
    Arboreal, Pete J, IanW and 3 others like this.
  12. Gareth Halfacree
    4 Dec 2007
    Finally got my replacement RAM, thanks to @MLyons, and I'm back at 32GB. Huzzah!
    Won't boot at the XMP profile of 3200-16, for some reason, but works fine at 3000-15 like the stuff it replaced. Good enough for me.
    Now to cross my fingers the return gets there OK and I get my refund in good time...
    IanW, Arboreal, MLyons and 1 other person like this.
  13. Gareth Halfacree
    4 Dec 2007
    Also, the movers might have let us down on the bulk of the stuff...
    ...but at least I've got my TV!
  14. sandys
    sandys Multimodder
    26 Mar 2006
    timewarp
  15. kenco_uk
    28 Nov 2003
    So glad I got this when I saw it:
    May the Schwartz be with you!
    IanW, Byron C, goldstar0011 and 2 others like this.
  16. Gareth Halfacree
    4 Dec 2007
    Another minor win today: my ancient Dell 1250c (a Xerox Phaser 6000B in Dell livery, really) colour laser's been playing up. Ran out of the usual 75gsm paper I use and snagged some of the kids' thicker (130gsm, maybe?) art stuff in a pinch - but got *terrible* transfer echo where the fuser hadn't quite fused. Bought some more 75gsm paper, and there's still faint echoing unless you use draft mode.
    There's no way to get a replacement fuser these days for less than the cost of a new printer, which'd be about £200 - and I'd have to get shot of all the spare toners I've got (which, to be fair, were all kindly donated by people on 'ere who also had 1250cs that died.)
    Had a hunt through the advanced settings in CUPS to see if there was anything that might help - and found a "Paper Type" option, which seems to control either fuser temperature or dwell time (or both.) Stacked the thing full of my 75gsm paper but told it I was using "Lightweight Cardstock"... perfect prints every time, without having to use draft mode.
    Now to see how many more years I can get out of the thing - bought over a decade ago for £100 with two full sets of toner!
    IanW, Byron C and adidan like this.
  17. DeanSUNIAIU
    DeanSUNIAIU Minimodder
    11 Aug 2021
    I’m still rocking a Brother HL1430 I got for free ‘coz someone binned it coz they didn’t realise you could replace the toner. I’ve had it 20+ years now.
  18. adidan
    25 Mar 2009
    Got a crappy canon jobby but I've kept it for easy scanning and photocopying when I need too.
    It does print but I have to do it in dark blue as the black has gone funky. I guess it could be cleaned?
  19. Mr_Mistoffelees
    26 Aug 2014
    How does somebody that dim, manage to use a printer at all?
  20. perplekks45
    9 May 2004
    Yeah, I wonder if they just get out and leave it standing somewhere when their car runs out of gas?
    IanW and Mr_Mistoffelees like this.
