Other What currently makes your life awesome?
Discussion in 'General' started by Brooxy, 28 Oct 2009.
  1. Arboreal
    21 Jan 2011
    Glad to hear that's a thing, last time I went for a beer in Winton, the choice wasn't great.
    If you're over my way, the Wight Bear in Southbourne Grove is an excellent ale house, and the new Drop the Anchor tap room in Tuckton is great. DTA is a newish small craft brewery in Christchurch, i know one of the guys, who has left his job and is doing it full time. Props to the fella, I hope it goes well for them
  2. ElThomsono
    ElThomsono Multimodder
    18 Mar 2005
    Good luck to the fella, I keep encouraging my mate to go into business for himself but I don't think he fancies the stress of it. I think it's the future though, drinking is on the decline and people prefer something decent when they do.
    I'm drinking in pubs less these days and when I do I prefer an all day low percentage session, so it's real ale all the way, or I will die.
    And three pints for £9 felt like a steal to me, although back in my home town it would have run you £5 :hehe:
    Arboreal likes this.
  3. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    Breakfast!
    Vault-Tec, Arboreal and perplekks45 like this.
  4. Gareth Halfacree
    4 Dec 2007
    *Man*, that is satisfying:
    Fits perfectly into a Kallax/Expedit/Whatever IKEA's Calling It This Year. There's not a whole lot of room for the top vents to do their thing, mind you, but front and rear are unobstructed while there's plenty of space at the sides.
    Vault-Tec, legoman, IanW and 2 others like this.
  5. legoman
    legoman breaker of things
    28 Feb 2010
    Like a glove...
    Had a rather crappy time of late (still is rather crap) after fitting the android disco gay bar RAM to the PC last night it kicked my modding brain back into gear. Doing it properly this time as I have way more in terms of skills. First up, seeing how the PC runs without a graphics card, then the fun starts.
  6. Mister_Tad
    27 Dec 2002
    The fact that it appears to be protruding an inch or so is making me twitch... please tell me it will sit flush.
    Even if it doesn't, please tell me it does anyway so I can carry on with the rest of my day.
    Dr. Coin likes this.
  7. Wakka
    23 Feb 2017
    If it doesn't, chase a hole in the wall and MAKE IT FIT.
  8. Guest-44638
    Guest-44638 Guest
    Ooops - OCD trigger event... I saw that myself, but guessed that Halfy was OK with the situation.
  9. adidan
    25 Mar 2009
    Triggered. I am very triggered.
  10. Wakka
    23 Feb 2017
    I bet it actually fits in fine, but G knew that picture would cause ripples...
  11. MLyons
    MLyons 70% Dev, 30% Doge. DevDoge Lover of bit-tech Administrator Super Moderator Moderator
    3 Mar 2017
    Found an undocumented API for some work I'm doing which is going to save me hours of trial and error. Just hoping it doesn't get changed.
  12. Gareth Halfacree
    4 Dec 2007
    Sadly I can do no such calming of your fretting mind: it's just slightly too long, sticking out at the front and back (or pick your own side, I guess.) I knew that'd be the case before it arrived, mind you, and the 'feet' are wide enough that it's flat and stable without the need for some form of supporting chock.
  13. Mister_Tad
    27 Dec 2002
    Phew. Good to know, thanks!
  14. legoman
    28 Feb 2010
    Only solution, a letter to Ikea to tell them they need to make the units deeper to house the case.
  15. Wakka
    23 Feb 2017
    Do you know where you are?!
    Only solution is a cut-and-shut. Take a dremel, remove enough of the case to shorten it to the appropriate length, glue back together. Everybody is happy.
    MLyons and adidan like this.
  16. legoman
    28 Feb 2010
    I venture the innards of that case may not quite fit :hehe: Its that or Mr Halfacre should get a LZ7, more maybe the forthcoming LZ7 XTD if he fancies a large graphics card. Either will easily fit into that space.
  17. Zoon
    Zoon Hunting Wabbits since the 80s
    12 Mar 2001
    Cut and shut two Kallax deep!
  18. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Simplest answer - pull the shelving away from the wall an inch or two. Makes running cables behind it easier too!
  19. Gareth Halfacree
    4 Dec 2007
    That one is actually free-standing, acting as a divider between the bedroom and the office.
  20. Arboreal
    21 Jan 2011
    Well that's the problem sorted....
    Push the case back so it's flush at the front, which moves the problem into another room, where we don't have to look at it! :p
