What do u think of this??
Discussion in 'Hardware' started by modderino, 20 Oct 2006.
  1. modderino
    modderino What's a Dremel?
    11 Mar 2006
  2. conteoAMD
    conteoAMD What's a Dremel?
    15 Oct 2006
    trash, i could build one for half that amount which equals that in power
  3. DougEdey
    5 Jul 2005
    If you want an off the shelf job, ask people at PCWorld, if you want us to reccomend you a pre-built system post in Hardware and Overclocking.
    NOT Tech Support.
  4. cpemma
    cpemma Ecky thump
    27 Nov 2001
    £300 then, with a 19" Sony monitor, legal XPMC, 1Gb ram, 160Gb HDD, TV tuner and the other bits? Really... :eyebrow:
    Moved to HW
    It's a very cheap (under £40) graphics card, looks like a very weak link in the system if you want games.
  5. TheoGeo
    TheoGeo What are these goddamn animals?!
    10 Jun 2003
    surfing the internet and the ocasional bit of office work would be fine. I wouldnt even attempt to run a decent game on that thing
  6. K.I.T.T.
    K.I.T.T. Hasselhoff™ Inside
    1 Jan 2005
    thats almost cringe worthy with an asking price like that...as for the x1300 i thought they stopped giving those out in happy meals ages ago
  7. modderino
    11 Mar 2006
    So can anyone suggest anything??
    or can someone build me something for cheaper but iwid more power??
  8. Noni
    Noni What's a Dremel?
    8 Dec 2005
    Look at MESH and Scan 3XS.
  9. specofdust
    specofdust Banned
    26 Feb 2005
    More power where? What is it you want to do with the PC? If you don't even take the time to tell people what you want to use the thing, you'll end up spending half a grand of something that quite probably won't be suited well to you. If you actually want to be pleased with this purchase, I suggest you learn a bit about PC's just by reading forums like this one, or at the very least go over what you actually want out of the PC.
  10. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Why don't you build it yourself?
    Most people here do, it's a top notch way of getting power, stability and looks for value.
  11. M4RTIN
    M4RTIN What's a Dremel?
    11 Sep 2006
    i really dont see whats wrong with that pc, as far as being a media centre is pretty well suited, could maybe do with a bigger hdd but other than that everything is geared to the media aide fo things, even that "crappy" x1300 is actually good as the x1000 series are very adept at decoding H.264 however it wont have hdcp so isnt in truth that good in the real world
    however for gaming its pretty crap
  12. Lineage
    Lineage What's a Dremel?
    19 Sep 2003
    "site currently down for maintenance"
    i think i have to check back later
