Modding what do ya think
Discussion in 'Modding' started by SpikeyJake, 17 Apr 2002.
  1. SpikeyJake
    SpikeyJake What's a Dremel?
    23 Sep 2001
    Since my first go at an lcd stand , was some what lame . I had another go and put a bit more effort into it. Iam trying to go for a Frozen type thing . As the MO/Bit-tech deal on the nk204 was so COOL :hehe:
    What do u think ???
    oh the leds are connect to gpos ;)
    chris
  2. linear
    linear Minimodder
    5 Oct 2001
    I approve! :D
    Nicely done.
  3. OneSeventeen
    OneSeventeen Oooh Shiny!
    3 Apr 2002
    I agree, Nicely Done!
    -OneSeventeen
  4. Mr T
    Mr T 4 Left Into Long 3 Right
    14 Nov 2001
    Was that one of them cheap photoframes from WH Smiths origionally ? It looks sweet love the frosting effect :D
  5. ::Dawg::
    ::Dawg:: What's a Dremel?
    14 Mar 2002
    Very nice, it gives me an idea. I also bought one of those LCD's on special.
    But, since i did a rush job and cut a hole on my Dell case it looks some what crappy. Also i have been having problems with LCDC but I will do a better job one day.
    I might suggest some how making a LED light up on the side. Take a Bl00 LED and shine it through the side of the frame that way it lights up the entire "Ice" effected frame. That is Plexi correct?
    :lol:
  6. Evilbob
    Evilbob What's a Dremel?
    28 Apr 2001
    That looks very nice, i agree with dawg's idea making the whole thing light up would look really Cool
  7. SpikeyJake
    23 Sep 2001
    Thx for the comments
    Yes it is on of them cheap photo frames . I told AW3K about it ;)
    humm good idear about the led . But the plastic is only thin and iam not sure how well it would work . Also it will be hard for me try now as i painted the edges with a blue paint . Something with didnt really come out in the photos .
    chris
  8. enfer_know
    enfer_know What's a Dremel?
    4 Mar 2002
    excellente'
  9. ::Dawg::
    14 Mar 2002
    Another suggestion for ya.
    Take some of that EL glo cable and make an outline of the frame with it.
    That would be purdy! and make me head :lol:
  10. Beaner
    Beaner What's a Dremel?
    14 Feb 2002
    Verra nice! I was just about to ask if the LED's are static or connected to GPO's, but then I caught it on the bottom. I think it's great, verry angular! I would love to see the entire face lit up though. My suggestion for that would be one of those tiny ccf's.
  11. AW3K
    AW3K What's a Dremel?
    3 Nov 2001
    :eeek: :eeek: :eeek: :eeek:
    very well done m8 that looks great.
    and thanks for reminding me that you told me about the frame :)
    i havn't got round to adding it to my site yet, been way too busy with college work, i will do eventually.
    very nice and keep up the good modding
    Later
    AW3K
  12. boooda
    boooda What's a Dremel?
    5 Mar 2002
    Nice man...
  13. Henry
    Henry Matrix Orbital
    13 Jul 2001
    Pretty funky!!!! I think I might have to start a collection of pics on our forum :)
  14. Digitalblueshift
    Digitalblueshift What's a Dremel?
    12 Feb 2002
    try getting some flat leds and setting them into little square notches you would cut in the back, that should liget up the plastic.
    Nice touch, looks like something out of the Fortress of Solitude, you should talk to LInear about whatever crystal thing he had going on in a thread somwhere.
  15. SpikeyJake
    23 Sep 2001
    thx for coments
    I might have a look into putting more light around the frame . But ive got another idear for a stand . Which will be my last try as i should start modding other stuff :worried:
    chris
