Cases What do you think makes for a 'good looking' case?
Discussion in 'Hardware' started by sotu1, 14 May 2010.
  1. sotu1
    sotu1 Ex-Modder
    24 Aug 2007
  2. Silver51
    Silver51 I cast flare!
    24 Jul 2006
    I've been using a Xaser III for years. Probably the only thing ever to come out of Thermaltake that was ever any good. Black with clean lines and built like a tank.
    It fits nicely in the room without looking out of place and is supah quiet. If I had to change it, I'd probably look at a Cosmos S. Cases should look good without being a distraction IMO.
    Pictured, my current case with the system running.
  3. SouperAndy
    SouperAndy To Bumble or not to Bumble?
    16 Feb 2009
    I prefer simple monolithic cases, such as Lian-Li's and the new Corsair 800...
    That said, the last two cases that I bought was the Antec 1200 and the GMC Toast in Orange?! But they were for a specific role.
    My favourite is the Lian-Li PC-350 for the HTPC.
    Cheers,
    SouperAndy :worried:
  4. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    My favourite case of all time is still the Chieftec Dragon (original model, not the modern crap)
    Only problem is cooling and internal component management is a little difficult. Fitting a long graphics card requires pulling out a HDD rack, However it's steel which means no rattling and excellent noise absorption
  5. 13eightyfour
    13eightyfour Formerly Titanium Angel
    9 Sep 2003
    I just want a soilid block of aluminium machined to fit everything inside, Kind of like a giant unibody macpro. No picture because i cant find anything that comes close! Possibly because price would be a massive issue (how much is a case sized block of aluminium anyways?)
  6. SouperAndy
    16 Feb 2009
    Probably more expensive than buying a macpro and replacing the insides :jawdrop:
    Cheers,
  7. Kyndylan
    Kyndylan What's a Dremel?
    9 May 2010
    I'm firmly in the minimalist school of thought - so things like the Fractal R2 Define, most of Silverstone's and Lian Li's options, and to a certain extent things like the Coolermaster CMII 690.
    Things like that Antec, and even your Thermaltake, Silver51, are too busy for my tastes!
    But hey, it's all opinion, right? World would be boring without the variety!
  8. ripmax
    ripmax Minimodder
    8 Apr 2010
    Really like the look of this.
  9. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    Modern, no frills, simple fridge like cases Antec P180 comes to mind and so does the Li Lian A71F
  10. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    My custom painted baby :)
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I quite like the new Silverstone Fortress FT02, especially since Scan have an exclusive version at the moment.
    [​IMG][​IMG]
    Isn't the red interior pretty? I'd prefer it with only one optical bay showing in the front though.
  12. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    I am another disciple of the industrial case design school of thought.
    The Dark Fleet is very pretty, and my own PC resides in a HAF 922 at the moment. Not a giant fan of large cases (pun intended) though industrial styled ones often seem to be. There's just something about a case that looks like it could (and hopefully really could) take a beating and remain functional, something that makes heavy "clunk" noises when you work with it, and something which provides factory-like functionality over looks.
    Wooden cases are also incredibly beautiful, though that's a custom thing and I'm not sure if it completely applies to this discussion. Once I work up the courage/skills to do my own mod it will hopefully be a wooden scratch build, with industrial functionality in mind of course.
  13. Jipa
    5 Feb 2004
  14. Amanda 1983
    Amanda 1983 What's a Dremel?
    10 May 2010
    I have an old Cooler Master Stacker STC-T01. I love it.
  15. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    The Beast has got the idea :)
  16. Moyo2k
    Moyo2k AMD Fanboy
    11 May 2009
    Thermaltakes one success looks like a cheiftech?
    Over the last year my taste has changed totally to the extent I now can't look atm my CM 690 twice, thinking about getting an R2 or something similarly smooth
  17. bestseany
    bestseany What's a Dremel?
    2 Jul 2009
    I prefer simple and slightly plain looks. I hate massive flashy showy cases with loads of windows etc.
  18. Trance
    Trance Two steps forward, one step back
    6 May 2009
    A mix between industrial and modern sleek minimalist thingymajig.
    O wait I got one of these :) but not in red :(
  19. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Sleek, and fairly minimal. Love my Cosmos, just not a fan of the silver anymore, soon to be Arctic White :)
    My first case was a ThermalFail Armour Jr. It had a blue LED fan, it had a window, and some totally useless fins infront of the drive bays... at the time I loved it, it was even more sexy that sex. Then I changed what I wanted.
    Not I want a Lian-Li :(
  20. memeroot
    memeroot aged and experianced
    31 Oct 2009
    +1 for the lian li
    however what I really want is one that looks like mecchano
