Modding What do you think of this case ?
Discussion in 'Modding' started by SiliconHell, 24 Jul 2002.
  1. SiliconHell
    SiliconHell What's a Dremel?
    30 Apr 2002
    I have been looking through loads of sites to find a case that looks 'differant' . So far I have only found one that really tickles my fancy is this (i apologise that I have no pic only a link)
    www.coolcasemods.com/info.php?id=22
    Now I know it is kind of similar , but it is my third case after the basic one I got when I bought my PC , and the Samuri Full tower that I bought at a computer fair . I think that this case is both value for money and has bags of potential . Here is what I intend to do . Any suggestions etc would be of great help
    Spray the beige areas black
    Install stealthed CD-RW and DVD-ROM
    Install black Maplin Transfer Panel
    Install 3.5" Black floppy drive
    Install home made Fan Bus onto a 3.5" floppy plat
    Delta Screamer 80mm Fan on 7v power supply as exhaust
    2 x YSTech 80mm intake fans
    2 x 80mm Blowhole in Exhaust with 2x YSTechs
    Cutting a hole in the front panel and adding ducting
    Rectangle Window , with Biohazard Etch
    2 x Blue Cold Cathodes
    Loads of those coolermaster cable covers
    Re-Attachale of Slot Coolers
    New Heat Sink
    Some funky mini-sinks from The OVerclocking Store for my slots
    Possibly 120mm blowhole on top to get rid of dead zone
    Neon String around the silver bits
    Changing the power LED's for Bloo ones
    An IR reciever for general coolness (You need a program called WinLIRC to run this , but I forget where you can get it from )
    So , what does every one think . If I go ahead I will post pictures for you all to drool over
  2. Yoda
    Yoda What's a Dremel?
    26 Jun 2002
    What kind of CDRW will you be using? :cooldude:
  3. SiliconHell
    30 Apr 2002
    Not sure . It came with my tower , so it probably not that good . It was a Mirai (Is that the right spelling) . Can't afford any decent new bits , spending all on the case and mods.
    Also , How do I get a picture next to my name (they are really cool)
  4. Yoda
    26 Jun 2002
    Well it looks like you have a pretty good idea what you want to do. so go for it.
  5. SiliconHell
    30 Apr 2002
    Thanks man , I value the support of everyone who is alive at this ungoddly hour , especially one as esteemed as you master jedi
