Cooling What do you use to clean Northbridge?
Discussion in 'Hardware' started by JonDixon, 11 Jan 2003.
  1. JonDixon
    JonDixon Decking is the new modding
    12 Mar 2002
    Just got a zalman nb32j (the gold coloured) northbridge cooler to passively cool my northbridge.
    What do people recommend to clean the original gunk that was used when Abit stuck their original hs/fan combo there.
    I plan to use Arctic Silver 3 instead of the supplied thermal grease with it.
    Im thinking I'd use acetone or isopropyl alcohol to clean it (probably some iso. alcohol on the zalman too, to get rid of any dust/fingerprints on it)
    Is this right?
  2. Haddy
    Haddy World Domination
    22 Jan 2002
    If its a thermal pad...I use a razor blade to get most of it off then goo be gone *yes thats the name of the stuff*.....
  3. JonDixon
    12 Mar 2002
    Thanks
    Unfortunately that seems to be US only.
    However after searching for goo be gone on google and after seeing a nice website about 'snowballing' found another link which suggests using acetone (nail varnish remover - watch me steal the missus')
    Ta Haddy - led me in the right direction
  4. Haddy
    22 Jan 2002
    Yea if ya got some paint thinner around thatd work too....
  5. bee2643
    bee2643 What's a Dremel?
    7 Mar 2002
    ya, u could use that, id just be careful cuz i dunno if those chemicals leave behind a residue that would counterreact with the ASIII or the silicon chip itself
    unless u use something like rubbing alcohol afterwards that fully evaporates :S
