What do you use to take screenshots of BIOS settings?
Discussion in 'Feedback & Suggestions' started by z4114, 15 Aug 2007.
  1. z4114
    z4114 FACE!
    25 Jun 2002
    As a documentation project for work, I'll need to take screen shots from a BIOS and then a LiveCD type environment. What do you guys do for your Motherboard articles?
    Thanks
  2. M3G4
    M3G4 talkie walkie
    13 Dec 2001
    Turn flash off on camera, try and frame it as best as possible then shoot the monitor! :)
  3. specofdust
    specofdust Banned
    26 Feb 2005
    A digital camera :p
  4. z4114
    z4114 FACE!
    25 Jun 2002
    Thanks for the quick reply. I'm stuffed then, heh. My guys have a hard enough time looking at actual screenshots, a digi-still will only confuse them. Mayhaps some creative VM work? Not so much for the BIOS bits but the Live CD environment.
  5. Tim S
    Tim S OG
    8 Nov 2001
    We take all of our BIOS shots with a dSLR+tripod in front of the screen. :)
  6. cpemma
    cpemma Ecky thump
    27 Nov 2001
    I did this somehow way back in the days of 286, DOS3 and dot-matrix printers, method here may work
    However, "If the BIOS supports a screen-print function, you're in luck. Otherwise, give up, it's not possible." Doesn't work for me, but then my printer's on a USB port.
