Cooling What does a Peltier do?
Discussion in 'Hardware' started by M_D_K, 13 Nov 2002.
  1. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    What does a Peltier cooler thingy do.
    As im interested in them for soem reason.
    :D
  2. ZapWizard
    ZapWizard Enter the Mod Matrix
    19 Sep 2002
    A Peltier is a heat pump,
    When electricity is pumped trough it, one side get's very cold, while the other side get's very hot.
    They due this at a expense though, they not only pull away heat from the cold side, and move it to the hot side, but also add in additional heat of their own. Meaning they are not very effecient.
    A 60 watt peltier may only pull 40-watts of heat away from the cold side, but add in 20 watts of their own to the hot side.
    In order to work more effecient you have to pull the heat away from the hot side, by using air, or even better- water cooling.
    Peltier in watercooling systems can often get well below zero degree's on their cold side.
  3. Haddy
    Haddy World Domination
    22 Jan 2002
    Pricture Provided by www.ProCooling.com
  4. ZapWizard
    19 Sep 2002
  5. M_D_K
    M_D_K Minimodder
    3 Apr 2002
    Thanks
    Tis very helpfull
