What Does your Desktop look like?
Discussion in 'General' started by alipuk, 11 Mar 2002.
Thread Status:
Not open for further replies.
  1. Ben
    Ben What's a Dremel?
    11 Aug 2003
    Samurize and it set-up for the CPU activity :)
    Ben
  2. rankie
    rankie What's a Dremel?
    12 May 2004
    I downloaded the wallpaper changer powertoy and I have that going through a heap of garfield and dilbert comics I have
  3. K
    K 528491
    31 Oct 2001
    Got my LCD set up, much better. More room :)
    :D
  4. Smilodon
    Smilodon The Antagonist
    25 Mar 2003
    problem is: i don't have photoshop... i have paintshop though... mabye i can make something there... but thanks alot anyway! :D
    edit: aha! i figured it out! :D
  5. unclean
    unclean SMP obsessive
    30 Dec 2003
  6. Smilodon
    25 Mar 2003
    ok.. this is how it turned out:
    this is my standard setup... the startbar is over on the other monitor, but i didn't bother to include that one, as the contens there isn't interesting for you anyway ;) (the image gets too big aswell)
  7. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    ...need to get my second monitor down here... :sigh:
  8. unclean
    30 Dec 2003
    heres my 19" mon. showing my bryce skills :hehe:
  9. Go4t
    Go4t i
    13 Dec 2003
    0ddity's computer glitched out and this happened
  10. Da_BaCoN
    Da_BaCoN Minimodder
    25 Aug 2002
    Smilodon, do you mind posting how you made the wallpaper? i've got paint shop also, so i'd like to know :)
  11. Smilodon
    25 Mar 2003
    ok.. this is for paing thop pro 8... but i guess it's pretty much the same for other versions aswell...
    first you make a new image the size you want... white background.
    then you open the effect browser...
    there you choose the add/remove niose folder... then you press add noise (should be far right)... then press modify...
    in the new window you choose uniform... and monochrome... then set it to about 60%... and press ok...
    then you open the effect browser again and choose the "blur" folder. Then choose motion blur, and press modify...
    choose the angle to 90deg. (or whatever you want it to be)... And set strength to anything over 60% (try with 80%)... press ok...
    now you should have a wery light alu color... and one edge looks a bit wierd...
    First of you just mark the area that looks good and stretch it so you get rid of the nasty edge...
    when you have done this you choose "adjust->brightness and contrast->brightness and contrast"
    there you set brightness to about -30 and contrast to about -20... press ok and volà!
    Hope this helps
  12. NuTech
    NuTech Minimodder
    18 Mar 2002
  13. [DE]FreD_S
    [DE]FreD_S Certified Specialist of Awesomeness
    6 Jan 2002
    Here's mine ... not very spectacular, but I like it :hehe:
    Cheers
    Fred
  14. Atomic
    Atomic Gerwaff
    6 May 2002
    May 2004 Desktop... click for large version.
  15. Da_BaCoN
    Da_BaCoN Minimodder
    25 Aug 2002
    Atomic, you happen to got a link to that wallpaper picture? me likes it
  16. Da_BaCoN
    Da_BaCoN Minimodder
    25 Aug 2002
    well, i just got a new laptop for graduation :rock: and i haven't had much time to play with it yet (only had it for 2 days, so.....) but i also just got my lip (re)pierced, so i'm in a bod-mod mood:
    the desktop (icons, etc.) are exactly how the pc came. the wallpaper is one i found and edited to give her blue eyes (the laptop has lots of backlit blue keys and all, so blue's going to be worked into the theme)
  17. unclean
    30 Dec 2003
    i decided to give it a go with some less hashed together skinning. half way through a samurize bar, i'm currently adding winamp buttons and msn offline/online contacts to it. the rose is boring i know, but until the duallie has finished rendering all my 2048x768 and 3200x1200 bryce abstracts im gonna leave it.
  18. Pygo
    Pygo Rick Relixed
    26 Jan 2003
    My guess is an HP.
    What kinda lappy? I wanna get one for typing on and stuff. Though I will be takin whatever os they stick on and hopefully get slacky or Knoppix or similar on it.
    And whadya pay.. ok.. well, whad your parents/whoever pay?. Not sure I want to spend over 1.5k.
  19. Da_BaCoN
    Da_BaCoN Minimodder
    25 Aug 2002
    you sir, are correct - it's an HP (a pavilion ze5730us to be exact). i'm mainly going to use it for taking notes, etc. in college next year, so it's plenty powerful enough for my taste. my parents said that they paid around $900 for it, though i'm not sure if that's before or after the rebate they got.
    i'm also going to use it to help me learn linux - gonna give gentoo a try (i've had my eye on it for a while now)
    *EDIT*
    and good to see you're back, pygobombe
  20. Jamie
    Jamie ex-Bit-Tech code junkie
    12 Mar 2001
    don't want to make K look like the only one with a mac
Thread Status:
