Modding What Dremel Is Best For Christmas?
Discussion in 'Modding' started by bumfluff, 30 Nov 2006.
  1. bumfluff
    bumfluff What's a Dremel?
    18 Aug 2006
    First I was going to ask for a guitar kit for Christmas, but I won't really have time to build it before I have my exams so I think I might ask for a Dremel as the fake that my Dad has is a bit rubbish. What Dremel is the best for around the £50-70 mark as there seem to be quite a few for that price.
  2. bumfluff
    18 Aug 2006
    That Dremel Scroll station looks absolutely brilliant, shame its £240...
  3. HowY
    HowY What's a Dremel?
    14 Feb 2005
    ROTO-ZIP!
    Just cant beat the 4" metal cutters and they
    even have a flex-shaft "snake" attachment that
    uses dremel arbors and tooling.
    Don't even own a dremel and laugh like anything
    when I see case windows cut with the little 1/2"
    cutters - dozens of them - kills me...!
    Get a tool that will find much more use!
    I own 5 routers and the 'zip and I've never
    even considered a dremel tool yet. It's just
    not as capable a tool but having something
    I can use around the house and not just
    small details is more important to me.
    my personal opine anyway....
    Guess if you want a small hand held
    router <ahem> engraver they fit the bill.
    The Zip offers much more tooling and power.
    have had good luck with mine anyway - cuts
    parts off cars (including frame rails & box sections)
    - Outlet boxes and window/door openings in drywall
    and paneling.... Cut about any case window no sweat
    ( and no changing bits! ) - did I mention it cuts?
    Have fun shopping and consider the other tools that offer
    similar options as well - Cheers!
  4. bumfluff
    18 Aug 2006
    Those Roto Zip things look pretty expensive though but do look very good for cutting. Are there other things similar as they do look very useful?
  5. Ultimate Gamer
    Ultimate Gamer What's a Dremel?
    3 Nov 2006
    but those roto zips are alot of money and i personnally think the dremmel makes better quality cuts :)
    I have a roto zip and a dremel
  6. bumfluff
    18 Aug 2006
    And any opinion other than that?
  7. Stuey
    Stuey You will be defenestrated!
    20 Jan 2005
    Perhaps the (relatively) newest tool? The 300 series is also decent and slightly more affordable but having used both I'd say the 400 series is a bit more comfy. Plus there are a few bits and attachments designed just for the new configuration.
    Now, you really cannot compare a rotozip to a dremel. It's like comparing a stovetop range and a heavy duty broiler. They will both cook your food, but for certain purposes you want the speed and power of the broiler (rotozip).
    One can also argue the merits of an angle grinder instead of a dremel. A doctor uses a scalpel to slice into people, not a 6" hunting blade. There are reasons for that - precision.
    I've seen Dremels everywhere from the Dentist's office to the Podiatrist's office, to university research labs. Don't knock it just because YOUR particular uses call for a different tool.
    Anyways, I'd say the Dremel 395 or 400-XPR. If it helps, amazon.com has them for $75 and $80 respectively. I ordered a text from amazon.uk and shipping was only about $15 or so. So... if the reverse is true too, it would only be ~45 GBP.
    Oh. Nevermind - the outlet's different, right? My tool is 40 miles away so I can't check to see if it supports both voltages. Still, it's something to look into.
    Worst comes to worst, if you eventually need more than a dremel + cutting kit (they do make rotozip-type attachments for the dremel), the cheapest angle grinder is about a third of the cost of the cheapest rotozip-type tool. But that's for when you need to cut through a chain link fence or a lot of steel or something. The roto-zip type bits for dremel are technically for "aluminum siding" but can work with a variety of softer non-metal materials.
    Oh, and you shouldn't really be so anxious when it comes to the timing of replies. People will see the post and reply gradually.
  8. bumfluff
    18 Aug 2006
    Ok, I think it is really between teh Dremel 8000 (thats the cordless one) and the 400, and opinions on which one?
  9. Stuey
    20 Jan 2005
    I vote no to cordless. I've heard way too many people complain about how the power drops off way too quickly. Perhaps it's been improved, but I'll still be skeptical.
    Worst comes to worst, you can pick up a 50ft (er, 15m?) extension cable for pretty cheap.
    What do you plan on using the dremel for? General purpose case modding or other stuff? Do you plan on cutting through steel or aluminum?
  10. Captain Slug
    Captain Slug Infinite Patience
    25 Nov 2001
    Get a jigsaw, power drill, and file set instead. Unless you plan on doing alot of engraving, a dremel is not the tool of choice.
  11. bumfluff
    18 Aug 2006
    Thng is for my needs, a jigsaw does not get into tight enough spaces, the case that I have requires a lot of cutting of plastics in soem confined spaces and difficult angles. What tool would be best for this?
  12. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    Go for the 400 xpr.
  13. hydro_electric_655
    hydro_electric_655 Dremelly Dude
    13 Jul 2006
    I bought a tungstun carbide cutting blade for my dremel. Made for cutting hardennes steel an dother hard stuff. But it works wonders on sheet metals. Steel aluminum w/e...
  14. Emon
    Emon What's a Dremel?
    14 Jun 2004
    Um, jigsaw. Autoscrolling to be precise.
  15. bumfluff
    18 Aug 2006
    I think I will go for the 400 XPR, the kit with the planer attachment as the one with the flexishaft is about £30 more. Good choice?
  16. hydro_electric_655
    13 Jul 2006
    Yu will use the flex but not the planer at least not for most use.
  17. bumfluff
    18 Aug 2006
    Yeah, I know but I can always get the flex thing at a later date as it isnt really essential and the planer one is cheaper, albeit with fewer accessories.
