Modding What Dremel?
Discussion in 'Modding' started by teamtd11, 30 Apr 2008.
  1. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    I am looking to get a dremel so i can do some needed case mods. looking on the internet i have spotted a Dremel 300 and a Dremel MultiPro Drill 395. my guess would be that the higher the number the better? Is that true.
  2. Tec_
    Tec_ What's a Dremel?
    26 Feb 2008
    just head on down to your local hardware store, they would be more than willing to set you up with a nice unit.
  3. Cheapskate
    13 May 2007
    As far as I know, Dremel INSIDES have not changed in years. 100% of the difference between those models and the 200 is the fancy plastic casing.
  4. teamtd11
    31 Aug 2005
    I bought a 395 for £31.50 which i dont think is a bad price. now i just need to wate for have some fun :D :dremel:
  5. hyperion
    hyperion Minimodder
    30 Jun 2007
    Just don't get a cordless one.
  6. jhanlon303
    7 Sep 2006
    I have a couple with the 2 speed switch - high and low - and a new one with the dial/knob thingy for speed control and I really like the control from the dial. Sometimes flat out is just too fast.
    I have a little blue cordless that can really get into tight spaces for sanding. Lasts about 1/2 an hour if you don't push. Great for detail on polymer clay - don't try to cut a window or a rad hole. :wallbash:
    Oh and Sciroco says to get a flexible shaft and leave it attached. Watch her work and you will see why. It's on my shopping list.
    My $0.02
    John
  7. teamtd11
    31 Aug 2005
    I like the look of that flexible shaft. I think that will be next on my shopping list aswell.
  8. Hazardous
    Hazardous What's a Dremel?
    21 Jan 2004
    The MultiPro 395 is no longer available from most places, unfortunately :(
    Which one to get, depends on how much you're willing to spend, and how often you're likely to use it.
    Seldom/low budget? Just get a 300.
    Often/higher budget? The 400?
    Granted... that 400 kit is expensive, but you do get quite a few very useful accessories with it... items which would cost you a lot more if you were to buy them separately :idea:
  9. teamtd11
    31 Aug 2005
    Cool. because thats what i have bought.
