Blogs What exactly is 'old-school modding'?
Discussion in 'Article Discussion' started by bit-tech, 11 Jan 2019.
  1. David
    7 Apr 2009
    IFTFY. ;)
  2. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Ah, I see what you did there.
  3. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    Old-school modding was back when it was niche and there was no big money involved. If you said "I'm modding my PC case" all you got was a blank stare.
  4. yuusou
    yuusou Multimodder
    5 Nov 2006
    There are only two things imho that are the clear separation of old school and modern modding.
    1) Vendor made parts
    2) Sponsors
    Everything else is just modding.
    Dot_Kappa likes this.
  5. Impatience
    Impatience Minimodder
    6 Apr 2014
    I'd agree with this tbh.. "Modern modding" is still just as impressive, although IMO it tends to be more a lot more based around making pre-made things fit together in a case, or making a case around the existing parts. And there's a heavy emphasis on making things "cleaner" from what i've seen in the last few years...
  6. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    "Old-school modding" brings to mind LED fans, cold cathode tubes (hey, remember those?), and DIY window kits.
    stonedsurd and Dot_Kappa like this.
  7. RedFlames
    23 Apr 2009
    not forgetting see-thru everything... acrylic cases... windows in HDDs...
    ...and UV. Loooooooooooots of UV.
  8. perplekks45
    9 May 2004
    THAT was exciting.
  9. jb0
    jb0 Minimodder
    8 Apr 2012
    It definitely was.
  10. lacuna
    lacuna Minimodder
    9 Aug 2004
    Not interested in the bizarre arguments over semantics here but just thought I would add to the list of people that are here because of Orac3
    MLyons likes this.
  11. Chris_Waddle
    Chris_Waddle Loving my new digital pinball machine
    26 Mar 2009
    I am in the school of others who have said that it's having the idea, seeing what materials you have / need and then trying to make it work with traditional handworkers tools. If you needed something unusual you had to build it. I was rubbish at it but it didn't stop me, ah the days of dropping a highlighter pen into distilled water to give your loop some colour!
    I have no issue with people using modern CNC's / 3D printers etc, some of the builds look awesome and I doubt some could be built without the aid of a computer controlling the tools. This is to me what separates modding and old school modding. I am of the belief where to class it as "old school" it should be done by your own fair hand and a mistake could cost you hours of work either starting over or finding a work around.
    My current build is the nicest looking build I have ever had. The thing is, apart from heat bend some tubes I've basically had just fit it all together into an existing case. Yes it took a while and some effort and planning, but to me it's not really modding.
    Dot_Kappa and The_Crapman like this.
  12. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    I don't care whether mods are old-school or new-school, cheap or expensive, hand-built or machined/printed. I care whether they are creative, clever, look amazing or are just plain cool. To that end, I take my hat off to all the modders on B-T.
    Dogbert666 likes this.
  13. Nexxo
    23 Oct 2001
    Old skool modding? Let's start with my Commodore 64: a toggle switch for shallow and deep reset, a bi-colour LED CPU status indicator, five switches to toggle between different kernel chips, one of which had a compiler/debugger, and one which came with the floppy disk parallel interface circuit, one PCB of which went in the C64, one of which went in the floppy drive and with a flatcable to connect them (the original floppy drive interface was serial, and s l o w).
    Other people also painted the case and added other bits and pieces:
    Because that's how we rolled in the 8-bit days.
    I concur with David and Crapman: old-skool modding is anything that involved the use of non-computer-specific parts repurposed for the functional or decorative enhancement of the computer. There were no off-the-shelf modding parts or components; we're talking aquarium pumps and hoses, worm clamps and plumbing barbs, heater cores from car scrap yards, rubber car window edging; cable ties and rubber gaskets and car spray paint.
    Vault-Tec, David, stonedsurd and 2 others like this.
  14. Dot_Kappa
    Dot_Kappa 100% Puppet
    23 Mar 2006
    Old school mods and old school work-logs. The funniest thing was to discover how to make parts, tools involved, solutions adopted and at the end.....looking at how all the parts fit togheter.
  15. jon
    jon Chief Phrenologist
    26 Aug 2009
    I still have my PimpRig sig file somewhere ...
    Been ages since I modded, but I read the logs here often ... the modern works are far more beautiful than we were able to make back in the old days. They are much more like art, though I won't take anything away from the folks who innovate -- I think that has always been at the heart of modding. My first mod was based on necessity -- the existing case (an old Dell!) simply didn't have enough cooling for my deployment to the desert. So, cut, poke holes, and mount. Not pretty, but it worked. People started adding more fans, windows, cooling options ... and case makers started offering cases that were "pre-modded" so to speak. My not-so-burning question over the years has been, what's next? What else do we need? My personal purpose for modding is gone -- case builders generally provide everything I need, somewhere -- but for others, the art and skill of modding is purpose all its own. I take my hat off to anyone who takes the time and effort to mod, on the smallest and largest scales, because we're making our rigs a bit more unique in the process.
  16. stonedsurd
    11 Mar 2009
    Orac3, Dark Blade, and that copper+carbon fibre mod that I'm forgetting the name of. IIRC the modder passed on (RIP) but the f***ing skill, balls, and commitment on display there was extraordinary. Oh, and Ang3l's artsy mods too -- not to my taste, but there was always something old skool about them. I love the aesthetic nowadays, but things just seem to move quicker, and feel easier and cleaner.
    And everything Attila did was stupid good.
  17. Stormtrooper
    Stormtrooper Shh...
    26 Mar 2004
    That was Langer with PrometheusCU for what it's worth.
    stonedsurd likes this.
  18. stonedsurd
    11 Mar 2009
    f***ing THANK YOU. I used to have it bookmarked, but somewhere along the many migrations, it must've been wiped. One of the all time greats, and it wasn't even finished. Wonder if it ever got completed? I remember being so gutted when news of Jesse's passing was shared. Not because of the mod, because it felt like we'd all been on this amazing journey thru PrometheusCu and now we'd lost our comrade... leader, even? Hell of a gut punch.
  19. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    For me old-school modding is a dremel (and jigsaw for bigger cuts), a set of tiny angled files, sandpaper and a big cardboard box re-purposed as a painting booth.
    I don't take anything away from the guys with access to laser/water cutters, big powder-coating ovens or anodising baths and all the material, tool and hardware sponsors, but the projects done in the back garden or shed with a couple of bags of stuff from Wilko's are the real heroes.
    CrapBag likes this.
Tags: Add Tags
