I have bought the £15 dremel copy and wa wondering if all the dremel accessories fit it as I want to get the bendy extension thing to get to those hard places to get to also can you get a pillar drill holder for it to that would be cool!!
They should all fit, three yrs ago I got a Ryobi (dremel clone) and have had no trouble getting Dremel accs to work in it.
I want to use........... I want to ge that pillar drill addon and I want to get one of those bendy extension things so I can get to hard to reach places it's called the flex shaft
I have a dremmel and the vertical drill press but i cant find dremmel drill bits anywhere! I bought a pack of mini-craft drill bits and, 1 they dont fit and 2 they're fecken' useless! I put one in the cordless drill from work and it took 6 minutes of continuous drilling to get threw my lian li faceplace AVOID MINI-CRAFT!
I bought a Dremel coarse grinding bit for mine (for £9 too ) and it doesn't fit. So I'd check diameters before you splash out.
