Small Form Factor What form factors are the shuttle motherboards?
Discussion in 'Hardware' started by Washfordmonkey, 11 Jul 2007.
  1. Washfordmonkey
    Washfordmonkey What's a Dremel?
    6 Dec 2005
    Considering buying a shuttle case to mod.. but dont want to pay out for the motherboard etc...
    so do they use a particular form factor.. or anyone know what other motherboards are likely to fit? :thumb:
  2. wbdog206
    wbdog206 not me
    15 Jan 2007
    if you look at the spec, sheets
    for the cases, it will tell you what
    each model will support.
  3. sk8ter646
    sk8ter646 Minimodder
    4 Oct 2005
    no other mobos will fit they all use bespoke mobos
  4. Washfordmonkey
    6 Dec 2005
    oh.. :( well thats blown that idea
  5. ArsoN
    ArsoN What's a Dremel?
    30 Sep 2003
    I thought they used FlexATX boards?
  6. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    but does anybody else produce flexATX?
  7. Moondog
    Moondog What's a Dremel?
    3 Jul 2007
    As mentioned earlier, they use proprietary boards of their own design. However, I read they plan to make replacement boards in the near future to fit their existing cases.
  8. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    No, it isn't Flex-ATX. F-ATX has three slots, Shuttle Form Factor has two, except for some of their older, smaller ones that only had one. If anything, it's closest to AMD's new DTX standard, but I have yet to see any DTX boards offered for sale.
  9. Washfordmonkey
    6 Dec 2005
    hmm i think i better give up then :)
  10. Tomm
    Tomm I also ride trials :¬)
    12 Apr 2004
    I believe it is known as flex-ATX, perhaps there are other variants of Flex-ATX from other manufacturers.
    You certainly used to be able to buy Shuttle mainboards from places, not sure you can any more though.
  11. unicorn13
    unicorn13 What's a Dremel?
    26 Feb 2007
    Flex-ATX, Micro-ATX, ATX only referes to the physical dimensions length x Width and the placement of the mounting holes along with the accepted location and positioning of the back panel conectors, keyboard etc.
    See this link (section 2) if i remember - http://www.formfactors.org/developer\specs\FlexATXaddn1_0.pdf
