Graphics What fps can I expect in BFBC2 with a 6870?
Discussion in 'Hardware' started by David164v8, 2 Sep 2011.
  1. David164v8
    David164v8 Minimodder
    29 Aug 2011
    And a q8220 @ 2.33 Ghz. My resolution is 1680x1050 and AA isn't really noticeable for me so I probably won't have that on. Oh and 4GB of DDR2
  2. David164v8
    29 Aug 2011
    Sorry. I meant a Q8200.
  3. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    At that resolution without AA it should handle it perfectly fine at high settings, although i dont own any of those specific hardware choices so cant comment directly.
  4. David164v8
    29 Aug 2011
    Also, what would be a recommended power supply? Looking to keep the cost down tbh.
  5. David164v8
    29 Aug 2011
    I'll just go for an Antec truepower 550w. Should be fine.
  6. scott_chegg
    scott_chegg Minimodder
    16 Feb 2010
    My single 6870 could run bc2 at ~70 fps at 2048 x 1152 all high and AA on my old q9550. It did dip from time to time but never enough to make it unplayable.
  7. David164v8
    29 Aug 2011
    Sounds great! Now I just need to make my mind up about a psu...
  8. jimmyjj
    jimmyjj Minimodder
    20 Jul 2010
    If you have everything maxed I would think you will be CPU limited and GPU limited both (depending upon the action on screen).
    Most of the time you will run at reasonable fps, but when there are a lot of explosions etc. you will see your fps drop significantly due to CPU usage.
    You will need to lower some settings to gain smooth gameplay, but not that much hopefully.
    Luckily the game multi threads very well.
  9. David164v8
    29 Aug 2011
    Yeah, my CPU is a disaster... Would it bottleneck a 560 Ti? I could probably stretch to it... But not much point if it'll be held back.
  10. scott_chegg
    16 Feb 2010
    550 w will do you proud. Oc the tits out of the CPU and you'll be fine. :)
    he's right tho. Bc2 batters CPU's.
  11. aLtikal
    aLtikal 1338-One step infront of the pro's
    7 May 2008
    Im running BFBC2 on the setup in my signature on 1680x1050 Full graphics. Perfectly playable no problems.
  12. David164v8
    29 Aug 2011
    Sadly I have a dell motherboard... Unless theres some other way to oc I'm screwed :|
  13. David164v8
    29 Aug 2011
    Is a athlon x4 640 @ 2.8 better than what I have? Because I was watching a vid Of someone play bfbc2 with it and a 6870. It was pretty smooth.
  14. Deders
    Deders Modder
    14 Nov 2010
    a Core2 quad should be better than any Athlon for gaming, even if it is half a gig slower, it still has a decent cache to make things smoother.
  15. David164v8
    29 Aug 2011
    Alright. Now I've just got 2 more things to sort out before I buy.
    1. Is a 560ti going to be held back? Or is it worth the £40
    2. What psu model? I'm not really familiar with psu's... ;3
  16. Deders
    Deders Modder
    14 Nov 2010
    a 560 will do you proud, and go even faster when you upgrade your CPU.
  17. David164v8
    29 Aug 2011
    Okay. Am I still safe with 550w?
  18. David164v8
    29 Aug 2011
    Hmm. Apparently you can set your FSB (whatever that is) in a program.. And it'll bump up speed. Sounds dangerous :D
  19. Bede
    Bede Minimodder
    30 Sep 2007
    You can, it's a powerful tool. Personally I use SetFSB just to get extra info about my CPUs, I've never been brave/foolhardy enough to use it to OC :D
  20. David164v8
    29 Aug 2011
    Hmm. I could buy a new mobo for my processor. With a new mobo + psu + 6870 I doubt i could keep it under £220.
