Graphics What GPU has the lowest idle power consumption? Geforce210 or HD5450?
Discussion in 'Hardware' started by Chicken76, 10 Nov 2012.
  1. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    Wikipedia lists 6.4 W for the HD5450, but nothing for the GeForce 210.
    What would you choose for a server that's mostly administered remotely?
  2. GoodBytes
    20 Jan 2007
    Intel graphic solution.
    The GeForce 520 is slower than Intel latest graphic solution.
  3. Chicken76
    10 Nov 2009
    What if Intel is not an option?
    Performance is not an issue. I'm only interested in idle power consumption.
  4. Deders
    Deders Modder
    14 Nov 2010
    According to Anandtech, they are both the same, but the 5450 is faster for 3d and I expect it will give you better video quality.
  5. rollo
    rollo Modder
    16 May 2008
    The lowest will be Any Amd card with core saver technology as it shuts down the GPu.
  6. Deders
    Deders Modder
    14 Nov 2010
    Never heard of a GPU being turned off completely, unless there is another GPU to do the 2D work, Even Aero uses some 3d funtions but most modern cards clock down to very low MHz on the desktop.
    Do you have any links for core saver tech?
  7. mm vr
    mm vr The cheesecake is a lie
    18 Nov 2007
    Is is possible to remove the graphics card entirely? If you just SSH or RDP into the computer, it shouldn't need one at all.
