Graphics What GPU to power a Dell U2711
Discussion in 'Hardware' started by flame696, 11 Apr 2012.
  1. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Right now ive decided to get the Dell U2711 i need a GPU to power it what one shall i get? Budget is not huge as spending £400 on the screen will knock me out for at least 2-3 weeks im looking to spend £200-£250.
    Not going to be gaming as much as i used to but i want to know that if one day i have the urge to game then i have a capable GPU to handle the latest games
  2. Mac_Trekkie
    Mac_Trekkie Source Engine's #1 fan!
    10 Sep 2011
    GTX 560 Ti 2gb with the ability to add another would be a good idea. 2x 560 ti 2gb will outperform a 1.5gb GTX 580. As usual, though, I'm gonna recommend waiting until the Kepler line is more fleshed out.
  3. Elton
    23 Jan 2009
    I'd say get a GTX570. But the realistic option?
    Wait until the Kepler line fleshes itself out. Then make a decision.
    I wouldn't go for the Ti 2GB, it doesn't have that much grunt to run all games very well at that resolution.
  4. flame696
    15 May 2009
    when is the kepler line coming out?
  5. fathazza
    fathazza Freed on Probation
    20 May 2002
  6. Nazata
    Nazata What's a Dremel?
    2 Sep 2011
    Only time will tell... Though I reckon more will be out before the month is out.
  7. Mac_Trekkie
    10 Sep 2011
    Yeah, the 448-core is great. Popped mine in a friend's computer to help convince him to upgrade from a 4830 on his U2711, runs battlefield 3 quite well, but definitely won't max it out.
  8. flame696
    15 May 2009
    what about getting a gtx 570 as i can pick one up for around the £150 mark?
  9. mucgoo
    mucgoo Minimodder
    9 Dec 2010
    A 570 for £150.
    Jump on it.
  10. Mac_Trekkie
    10 Sep 2011
    I'd get it at that price in a heartbeat. That's a phenomenal deal, and you can always toss another one on the board when it starts to slow down.
  11. GoodBytes
    20 Jan 2007
    What i would do is wait for Kepler med-range cards.
    You have the GPU to use your U2711 right now. You can play games with it, with the same level as now (with the same resolution as you have now). Not great, obviously but it's temporary. What you can do to avoid the blurry image due to lowering resolution, is have the monitor set to 1:1 pixel mapping (Your monitor supports that), so basically.. no scaling. You'll get black bars all around.
    Again, I know it sucks, but at least it will allow you to wait until Kepler lower end models. They are no official date set... but usually it's not far off from the flag ship. So probably end of this month, or the next.
  12. flame696
    15 May 2009
    you think my 8400gs will cope? also what about using the onboard GPU on the Maximus GeneZ/GEN3 via HDMI?
  13. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    :jawdrop: tell me more... :D
  14. j4mi3
    j4mi3 What's a Dremel?
    28 Jun 2011
    Wait for mid range kepler man.
    I hav been managing for 6months on a 4870 ;) hows that for motivation
  15. dirky90
    dirky90 Minimodder
    19 Mar 2012
    what, a 570 for WHAAAT???? where where where??? sli anyone??
  16. GoodBytes
    20 Jan 2007
    Sure.
    If my GTX 6600GT can power a 1920x1200 screen resolution, I am sure the GTX 8400GS can manage Windows desktop, surf the web.
    As for games, it comes down to resolution.. so lower it to what you have now, (assuming same graphical settings, of course), will lead you with the same performance, as you have now. (Assuming you play your games in full screen and not in window mode, else you'll run the game PLUS Windows desktop and that might be too much.)
    The only time I see your 8400GS struggle is if you have a lot of windows open. It will be fine.. but you'll see a bit of choppiness.
    As for your onboard GPU of your ASUS Maximus II for Core 2 Duo CPU's, (I assume that is what you have), Doesn't have any video output, so I don't know which modem you are referring, same for your Asus P5K-E WiFi AP.
    But what I can say is that the max resolution via HDMI on Intel GPU's and your U2711, is 1920x1200 or 1920x1080 depending on your aspect ratio of your monitor. This is due that the Dell U series, has HDMI 1.2, same for Intel solution. The selection of this older HDMI connectivity probably has to do with the really high royalty fees imposed onto HDMI connection.
  17. flame696
    15 May 2009
    sorry goodbytes i have changed my rig i know have my Asus Maximus GeneZ/GEN3 running a i3 2120 so thats why i asked if i was better off using the onboard GPU via HDMI
  18. GoodBytes
    20 Jan 2007
    Ah ok, well same applies. Limited to 1080p via HDMI, by both the monitor and the Intel graphic solution. In term of gaming.
    The Intel HD Graphics 2000 in your Core i3 should be a bit faster than your 8400GS on popular games, and expect some non-popular games to have large performance issues, or not work at all, and don't expect any good quality drivers, like what Nvidia and AMD provides, and don't expect often updates.. in fact expect 0 update as soon as a new CPU is out.
    The problem in using your Intel, is that even on your desktop, you'll be limited to 1080p. So if you set your monitor is scale, you'll get hard to read text, and if not, you'll get a black surrounding all around, until you get a new GPU. So that would be the sacrifice, in your case.
  19. jakobfrimmel
    jakobfrimmel What's a Dremel?
    2 Jan 2011
    GTX 480 in sli or tri sli??? if u can find them cheap about!!
    otherwise a gtx 570 if u can really get em for 150!!
  20. Pookeyhead
    30 Jan 2004
    Get one 448 core GTX560Ti now... then add another in a little while. That's what I'd do.
