Graphics what graphics card cooler ?
Discussion in 'Hardware' started by Pie_uk, 22 Nov 2005.
  1. Pie_uk
    Pie_uk British beef, in Britain
    6 Apr 2005
    ok i can't decide to get a zalman fatality gpu cooler or the series 5 from artic cooling for my 7800gt. any help? view? cheers :)
    i am tempted by the looks of both, but the DHES is also verytempting with the artic cooling.
  2. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    I'd say go with the arctic cooler, I've had nothing but good service from the 3 i've used, compared to the 7000 series cpu cooler i have whose performance has been somewhat underwhelming.
  3. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Get a normal VF700 CU or ALCU for GPU tbh, cools better than the VGA silencer and looks teh sex
  4. AWACS
    AWACS What's a Dremel?
    10 Jun 2005
    and the fatality version is a lot louder thatn the normal version... and you can leave a pci plate open and the zalman vill exhaust air aswell
  5. hitman012
    hitman012 Minimodder
    6 May 2005
    I would go with the Arctic Cooling system... a DHES, good cooling and low noise levels are not to be argued with.
  6. Pookeyhead
    30 Jan 2004
    watercool it!!!
    @ 565MHz here... 31 degrees being spanked! More difficult I know, and not cheap... but well worth it, even if it's GPU alone.... but while you're at it.... :naughty:
    EDIT: Typo.. sorry.. 41 being spanked.. 32 idle (actually 28 at the mo, but it's very cold in here).
  7. Masterngc
    Masterngc What's a Dremel?
    30 Aug 2005
    Go with the arctic cooling
  8. Pie_uk
    6 Apr 2005
    yer and the zalman looks more tricky to install. thanks for you input guys :) :thumb:
  9. Highland3r
    25 Jul 2003
    Zalmans easier imo ;)
  10. AWACS
    10 Jun 2005
    hmmm... actually I'd say the other way around on tricky install... since on the arctic cooling coolers you need to make sure the big surfaces make perfect contact on the whole card on gpu and the ram
  11. westie
    westie What's a Dremel?
    31 Jul 2005
    I'd say the arctic cooler looks easier to install.
  12. AWACS
    10 Jun 2005
    maybe looks... but it isn't... with the zalman you have all separate surfaces and just easy mounting... but the arctic coolings ones are a big pieces which has 5 points of contact (gpu and 4 ram chip) and to get all thos points to get good contact will be tricky... cus if you fail, then you can most likely kiss your graphics card good bye
  13. Highland3r
    25 Jul 2003
    Quite. The older silencers are ok, but the newer ones with the scaffolding stuck to the back are a PITA.
    Can fit an "old" silencer in ~ 3 mins (use a modded mounting bracket) and the Zalman takes 5-10 just cos you need to tighten the bolts down evenly (again though using a modded mount) the stock mount on the Zalman looks a lot easier tho IMO
  14. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    neither are easy but i slept better with the zalman. Ohh and it got better temps by about 2c
  15. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Totally. Rev2/3 VGA Silencers were (and still are, if you have a card they fit) amazing, the new ones just leave me cold. Much prefer the VF700.
  16. Pie_uk
    6 Apr 2005
    yer well the latest one is the artic cooler 5 rev 3 , .... but how does it cool the memory on what would be the top of the card, i do remember with my x800xt that it was a great big plat on top as well as having the fan on the top, does the 7800gt even have memory both sides? im getting my self into a right pickle lol
    but i do like the look of the zalman one tbh
  17. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Obviously the Zalman, its sponz0red by Fatal1ty, so its obviously going to pwn so much of everybodys ass. :worried:
    ahem
    No, really, I would go for the Zalman, i think it is easier to install and looks way better IMO.
    And its sponsored by Fatal1ty, durr
    (i actually hate all the pointless sponsored hardware that Zalman have. "omg its exactly thr same as the stock one but costs more ")
  18. Shadowed_fury
    Shadowed_fury Minimodder
    21 Nov 2003
    You know Zalman, abit etc have to PAY for that sponsoring, insanity.
  19. AWACS
    10 Jun 2005
    I was just about to say that it's zalman and abit who sponsor fatal1ty... and if you honor silence then stay away from the fatal1ty model and get the vf700 cu
  20. Techno-Dann
    Techno-Dann Disgruntled kumquat
    22 Jan 2005
    Arctic cooler 5 rev 3. There's no ram on the back of the 7800 GT, so you won't have to worry about cooling it.
    In my experience, the Arctic coolers are quieter than Zalman coolers.
