Graphics What Graphics card under £150 is best for me?
Discussion in 'Hardware' started by Jaffdude, 11 Dec 2012.
  1. Jaffdude
    Jaffdude What's a Dremel?
    11 Dec 2012
    I play mostly War Z and Day Z and I want to boost my FPS (Getting 14 - 20 at the moment)
    So I guessed the best way to improve FPS is to get a new graphics card so what's the best one I can get for under £150? Or if there is a better way to boost FPS please let me know. :)
    Here's my stats:
    - Case : Galaxy 3 Gamers Style Midi Tower Case
    - Motherboard : Gigabyte M68 Motherboard Technology
    - CPU : AMD Bulldozer Six Core 6100 3.3ghz
    - Hard Drive : 1TB Sata Hard Drive
    - Memory : 8gb DDR3 1333 Memory
    - Optical Drive : 24x Dual Layer Sata DVD Writer
    Graphics Card : ATI Radeon 5450 1gb DDR3 with HDMI With Hyper Memory Upto 2gb
  2. Jaybles
    Jaybles What's a Dremel?
    12 Feb 2011
    New: Radeon 7850
    Second Hand: GTX 570 possibly a 580.
  3. David
    7 Apr 2009
    Yep, a 2GB 7850 will make a decent upgrade although, with £150 budget, keep on the lookout for a bargain GTX 660 (non Ti) - you can get them for £160, so Scan's today only and Aria's superspecials (among others) should be on your regular browsing schedule.
  4. Zinfandel
    Zinfandel Modder
    2 Aug 2010
    Don't forget the 660 MSI on Scan has AC3 which presumably you could sell.
  5. Madness_3d
    Madness_3d Bit-Tech/Asus OC Winner
    26 Apr 2009
    Probably worth checking your PSU is up to it
  6. Slizza
    Slizza beautiful to demons
    23 Apr 2009
  7. chewbaccas_nan
    chewbaccas_nan Minimodder
    27 Jun 2011
