Education What grit sandpaper?
Discussion in 'General' started by Kronos, 28 Jan 2018.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    As a project for the summer I want to repaint the metal banister/railings leading from my floor to the ground as now all but one of the flats in my block are now privately owned rather than council owned we are now responsible for maintenance though the council would still be responsible for a share as they still retain ownership of one flat.
    There is no rust to be concerned about but the old paint is certainly well chipped and worn. So am looking to sand it to a reasonable condition but not spend that much time doing so, then priming and adding a final coat.
    So what grit paper?
    Will any primer do?
    What about final coat?
    This is an odd job for me to be taking on as last year when I finally finished redecorating, refurnishing the whole flat I vowed at 64 I would never ever need to touch a paint bruch, pasting table again in my life as I hated it.
  2. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    From my experience it depends on how good you want the end result to be, a bare minimum would be to key the old paintwork using paper around 180 grit and slapping your finishing coat on. If you're not taking it back to bare metal you won't need a primer or undercoat..
    Quick job would be keying the old paintwork and slapping on whatever gloss you want, longer job would be stripping it back to base with a chemical paint stripper à la Nitromores, priming with a primer suitable for metal, 3+ layers of undercoat, 180+ grit sanding to remove brush strokes and finishing with a gloss.
    If you're going the quicker route, i would, you might want to look at hammerite type gloss as although it's a bit more expensive the hammered finish does a better job of masking imperfection.
  3. Vault-Tec
    30 Aug 2015
    If you use something like smoothrite you don't need primer either IIRC. It's also very hard wearing and you can thin it down slightly using turps. Hammerite is the same, if you like the finish :)
    I wouldn't aim for perfection though. If you do that means basically bare metal etc etc. Clean and presentable is much easier :D
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    I think you will find the Nitomores is a shadow of it's former self and pretty rubbish now. Anyhoo I am looking for the quicker option. A bit of a sand to remove any loose chips etc and hopefully provide a key for the new paint. Like the idea of not having to use a primer.
    Clean and presentable is what I am looking for so will look at Hammerite and Smoothrite will be on my list of paint choices.
    Vault-Tec likes this.
  5. Corky42
    30 Oct 2012
    Forgot to say if the old paint if flaking in places you may want to give it a quick going over with a wire brush to remove the loose stuff before keying.
  6. legoman
    legoman breaker of things
    28 Feb 2010
    While Nitromores is now rubbish, Loctite 790, dissolves paint very very quickly. Its basically there gasket chisel in a different tin.
    Re did an only bench the other year, wire wool/brush to de flake the paint as corky said, sand 180/240 grit, Outdoor primer like red oxide, couple of coats then paint with something like Galvafroid which is an anti corrosion paint.
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
    I don't think that I am going to go the strip the old paint off route just want to make the banister a bit more presentable.
    My banister is internal so I do not feel the need for red oxide though I am sure we called in red lead when I was on board HMS Bachante.
  8. Vault-Tec
    30 Aug 2015
    If you go for a full strip you are looking at a crap ton of work. Even with the best stripper in the world (which would be that aircraft stuff). It's massively involved and will take you forever. Plus when you are done using that you need to hose/wash everything down or it wrecks the paint going on. A bit hard on an internal stair case..
    I would wire brush it to get rid of anything loose and any major rust. Then give it a light sanding just as a key and use either Smoothrite or Hammerite. Both can be applied to rust and both contain an inhibitor to cure it and stop it getting worse.
  9. legoman
    28 Feb 2010
    Yeah same stuff, F69 Leander class? Not the worst posting in the world!
  10. Kronos
    Kronos Multimodder
    6 Nov 2009
    Unfortunately I was a daft wee laddie at the time and although I went all over the world on that ship I do not have one photograph as a memory. On one occasion we had around 200 dolphins slaying around the ship as we shifted along in a hurry to get I cannot remember where. Great times wasted on the youth.
  11. play_boy_2000
    play_boy_2000 It was funny when I was 12
    25 Mar 2004
    A wire wheel on a drill works wonders, just remember to goggle up :dremel:.
    The_Crapman likes this.
  12. Kronos
    Kronos Multimodder
    6 Nov 2009
    There's an idea, thanks.
  13. alfizzle
    alfizzle Ooh aah just a little bit..
    3 Apr 2013
  14. Kronos
    Kronos Multimodder
    6 Nov 2009
    alfizzle likes this.
  15. alfizzle
    3 Apr 2013
  16. Cheapskate
    13 May 2007
    You might want to use a small roller if you are not spraying. I've found using a brush on rails takes forever. You will still need to touch the cracks and tight spots with a brush.
  17. Kronos
    Kronos Multimodder
    6 Nov 2009
    Way ahead of you on that score mate, I rarely use a brush these days so had already planned to buy a few more mini roller heads and a couple of small brushes.
  18. Cheapskate
    13 May 2007
    :thumb: I had to do a job on a house where the buyer wanted rails added between rails and painted. The house had a 3 story main living area with a raised partition, stairs, balconies running the length of the house on either side of the room, and an open walkway between them. We added several hundred rails and had to brush paint the whole lot.
