Modding What handle to get?
Discussion in 'Modding' started by Bboy_Jon, 10 Aug 2005.
  1. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ok i was gona go to homedepot to get a handle (home depot is like 30miles away) but now i found out ace hardware (8miles away) has the same exact stuff, its AWSOME i seriously didnt think they had stuff lol
    but which handle should i get? i only need one
    handle 1, is a small maybe 4 inch long handle, just how it looks (its a drawer handle, can it support the case?)
    http://www.acehardware.com/product/...1&doVSearch=no&pageBucket=0&parentPage=family
    like that but its rounded, not flat (or should i get the flat? its longer)
    2 is a garage door handle, theres one with a striaght/flat middle and theres one with a round middle which one? they have 2 in a pack
    3 is just a regular type handle, heavy duty
    i could get one of these
    http://www.acehardware.com/product/...9&doVSearch=no&pageBucket=0&parentPage=family
    but in silver
    edit: heres what number 1 is
  2. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    use the handle off an army ammo box... those are shibby, cuase they fold flat, but are really good and sturdy..., just take one off a current box and polish it up
    happy modding :dremel:
  3. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    i dont know how i would take it off
  4. OtakuHawk
    OtakuHawk What's a Dremel?
    30 Apr 2003
    drill out the rivets.
  5. theurgy
    theurgy What's a Dremel?
    8 Oct 2004
    It all depends on what case you have.
  6. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    i have a blue raidmax scorpio
    no rivets on any of my army can things, plus it would look retarded
  7. theurgy
    8 Oct 2004
    For the Scorpio I would pick #1.
  8. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
  9. MiLwOrkZ
    MiLwOrkZ What's a Dremel?
    6 Feb 2005
    It Will support the case but i would get some diff. hardware and use a washer on the inside to make sure nothing will pull through! Also i have seen those handles they make them longer though just look on a tall Cubed display by the DoorHandles and it will be at the bottom! Trust me they are there!
  10. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    ya i didnt look at the door section, i was so amazed that they had stuff there, i only looked in like 1/4 of the store
    But ya ill use washers
  11. MiLwOrkZ
    6 Feb 2005
    WHEREABOUTS do you live in missouri i used to live in Springfield actually in ozark 15 miles south!
  12. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
    i live in columbia
  13. MiLwOrkZ
    6 Feb 2005
    ohh ok well i was gonna say if you were going o go to Springfield home Depot i could tell you exactly were to look!
  14. Bboy_Jon
    Bboy_Jon Minimodder
    28 May 2004
