Hardware What Hardware Should I Buy? - April 2009
Discussion in 'Article Discussion' started by Tim S, 4 Apr 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. *mat-ster*
    *mat-ster* What's a Dremel?
    10 Mar 2002
    Nice selection
    Optical Drive
    First Choice: LG GGGC H2OL Blu-ray, HD DVD DVD-RW combo drive
    Should that not be LG GGC - one extra G.
    Also what about the "V2" P6T Mobo...
  3. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    intel Pentium?
  4. Buzzons
    Buzzons Minimodder
    21 Jul 2005
  5. wyx087
    wyx087 Multimodder
    15 Aug 2007
    not p182 for primary case choice anymore! have you guys gone the tacky route?
    gamer workhorse UK price has a dollar sign ;)
    and for premium selection, i thought your group test showed TRUE to be the best performing, is it because of the mounted wiggle?
  6. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    good to still still still see the q6600 going strong.
  7. Guest-16
    Guest-16 Guest
    It's a brand only, it's Core 2 architecture underneath.
    RE: Q6600 - I wanted to drop it, but Baz found a price we literally cannot ignore in the UK so it stays in. I did want the Phenom II X4 940 or Q9550.
  8. aron311
    aron311 What's a Dremel?
    14 Jul 2007
    You've left a bit of a price gap here in the displays, at £320 i think the BenQ FP241W still deserves a mention, as theres nothing between £165 and £425...
  9. Star*Dagger
    Star*Dagger What's a Dremel?
    30 Nov 2007
    amazing what 1000 pounds will buy in pc equipment these days. Thanks for the article
  10. mauvecloud
    mauvecloud What's a Dremel?
    4 Nov 2008
    I notice the 30inch monitor you're listing is still ridiculously expensive. If you want 2560x1600, I know of two such monitors available in the US that are now available for less than half the price of the NEC model you list (I live in the US, so I don't know how much they are in the UK):
    Samsung SyncMaster 305T
    Gateway XHD3000
    Is the NEC model really enough better than those to justify the $2000+ price?
  11. ¦Cold¦
    ¦Cold¦ What's a Dremel?
    24 Feb 2009
    I'm pretty sure the E7x00 series is branded Core 2 Duo; the E5x00 is branded Pentium Dual-Core.
    I also agree that there should be another monitor in the ~£250-£300 range, maybe a budget 24-incher.
  12. karsh
    karsh What's a Dremel?
    2 Sep 2008
    yea, finaly the HP LP2475W in the list ;-)
  13. Guest-16
    Guest-16 Guest
    Of course, because it is THE BEST 30" you can buy. It's phenomenal if you have a lot of money to spend on a lot of real estate. Just like if you want THE BEST pc you have to pay through the nos for it.
    I havent seen the Samsung and have no idea what the Gateway uses sorry.
  14. GoodBytes
    20 Jan 2007
  15. Guest-16
    Guest-16 Guest
    The UK has a much more aggressive price for Nvidia cards, but the US gets better prices for ATI - that's why so many American sites are recommending 4890s right now.
    Your GTX 260 prices are crackers - DO NOT buy that.
  16. Denis_iii
    Denis_iii What's a Dremel?
    1 Jan 2007
    Scythe Kama Angle looks sweet, especially in a Antec 300 or similiar cases with top and rear exhaust fans
    any upcoming review?
  17. GoodBytes
    20 Jan 2007
    I know.. when I got my GTX 260, I paid~ 300$ after taxes and shipping.. now it's high price where ever you look (same for other Nvidia cards)
  18. MiNiMaL_FuSS
    24 Dec 2003
    a nice clocked q6600 can't be beat bang for buck :)
  19. mauvecloud
    4 Nov 2008
    The Gateway is better for me because of the extra inputs - I have 5 gaming consoles (SNES, N64, GC, PS2, X360) hooked up to it through a Pelican System Selector Pro. As far as what panels the monitors use, I've read that the Samsung 305T and Gateway XHD3000 use the exact same model of S-PVA panel internally, but the Gateway adds extra inputs, speakers, menu options, and a remote control.
  20. Dreaming
    Dreaming What's a Dremel?
    31 Jan 2007
Tags: Add Tags
