Hardware What Hardware Should I Buy? - August 2009
Discussion in 'Article Discussion' started by Tim S, 11 Aug 2009.
  1. specofdust
    specofdust Banned
    26 Feb 2005
    Really reckon it's worth it with a budget of 2-250 for CPU/Mobo/Ram? If you say it is, I shall trust ye :D
  2. Guest-16
    Guest-16 Guest
    What have you got now?
  3. specofdust
    specofdust Banned
    26 Feb 2005
    E6300 at 1.8Ghz because I voltmodded my motherboard just a little bit too much and wrecked it, and 2GB of 6400.
  4. Guest-16
    Guest-16 Guest
    £250 won't get you i5, mobo and memory. Not if you look at the price of an i5 alone. Although it'll be a nice jump.
  5. specofdust
    specofdust Banned
    26 Feb 2005
    X3 720 it is I guess. Cheers.
  6. Guest-16
    Guest-16 Guest
    You might want to consider saving instead *hint*
  7. specofdust
    specofdust Banned
    26 Feb 2005
    Your hints always confuse me <3 - Will hold on and see what I can sell.
  8. wyx087
    15 Aug 2007
    £100 mobo + £150 i5 750 + £60 4GB DDR3 RAM. very affordable, and reachable with a bit of saving ;)
  9. Guest-16
    Guest-16 Guest
    We're still evaluating the £100 mobos to see whether it's worth pairing with an i5, but what you've got there is over £300 :p Plus that DDR3.. £60 is a bit optimistic unless you go for very cheap stuff - prices went up recently iirc.
  10. perplekks45
    perplekks45 LIKE AN ANIMAL!
    9 May 2004
    My question would be:
    Is it worth upgrading from an E6600 @ 3.6 GHz with 4GB PC6400?
    But I guess I'll have to wait for Tuesday to get an answer, right?
  11. wyx087
    15 Aug 2007
    DDR3 prices is a bitch. was £70 for very nice tri-channel, and now it's £70 for some average dual channel.
    had to pay £135 for the now-average Dominators. ones i got are probably Corsair's first batch of DDR3, only 1600Mhz cas9.
    like P35 and P45, surely, i would have thought lower prices on motherboard would just mean less stuff, no "drive xpert" or express gate that won't be used and doesn't work on AHCI (respectively)
Tags: Add Tags
