Hardware What Hardware Should I Buy? - February 2010
Discussion in 'Article Discussion' started by Lizard, 3 Feb 2010.
  1. Lizard
    Lizard @ Scan R&D
    17 Feb 2007
  2. alastor
    alastor Minimodder
    6 Sep 2004
    No monitor section? I always liked that bit...
  3. Guest-16
    Guest-16 Guest
    We haven't had one for a year.
  4. mi1ez
    mi1ez Modder
    11 Jun 2009
    hmmm... i5-750 looking more and more tempting to replace the Q6600 but I think an SSD may come first...
  5. Baz
    Baz I work for Corsair
    13 Jan 2005
    funny you should say that....
  6. tad2008
    tad2008 What's a Dremel?
    6 Nov 2008
    I agree that we should have a monitor included and that it has been long neglected, perhaps a summary or a "What Monitor Should I Buy" over in the Monitors section?
    Overall though, a good and refreshing look at the current hardware out there and it was a pleasure to see some new recommendations put forward.
  7. Xir
    Xir Modder
    26 Apr 2006
    Nothing to be proud about :blah:
  8. bogie170
    bogie170 What's a Dremel?
    11 Aug 2008
    Still no room for a Corsair H50-1 for a CPU cooling solution. Its a few quid more but leagues ahead of any air cooler.
  9. Guest-16
    Guest-16 Guest
    It was a statement, not a brag.
    I've said it many-a-time before, we simply don't do enough monitor reviews. :(
    It's good, but it's not leagues ahead and it has case dependent performance.
  10. memeroot
    memeroot aged and experianced
    31 Oct 2009
    great to see the fractal case in the mix, no aditional fans though - would that not negate the non stock cooling on the cpu?
    on the monitor side - i'm looking for a new one and would like a review of the various 120htz models - the GD235HZ seems worth the wait.... though I understand that these are not as good as other non 3d monitors however it'll be a second monitor and is there only for the gaming...
    prices seem quite high this month and they're feeling a bit cut and paste... not enough new tech out, or price changes I guess. Could do with a bit of spicing up somehow though - include a dremel?
  11. CopaMundial
    CopaMundial What's a Dremel?
    2 Dec 2009
    I've got a ati 4870 1gb is it worth upgrading to a ati 5870?
  12. stoff3r
    stoff3r What's a Dremel?
    20 Nov 2006
    I have the same question :) Or, to put it in another context, I have problems running Stalker clear sky at good resolution with dx10 high, and need advice :) Heres my rig: Q6600, 2x2GB kingston 6400, Abit IP35pro, 4870 512mb. Monitor is 1680x1050 resolution. My mate have a 3.5ghz q9550 or something, and 4870 1gb, he runs it quite fine actually. So, do I need more MHZ, or 1GB gpu? Or maybee Intel SSD ? :p
    It would also be nice to see a monitor roundup. Thanks :)
  13. salesman
    salesman Minimodder
    29 Apr 2007
    I see you have a U.S. price for the Titan Fenrir. Could you link the retailer?
  14. flibblesan
    flibblesan Destroyer
    27 Jul 2005
    Only if your 4870 isn't giving you the high framerates you need.
  15. Cyberpower-UK
    Cyberpower-UK Professional Overclocker
    6 May 2009
    It would also be nice to see a monitor roundup. Thanks :)[/QUOTE]
    OC your Q6600, add 2GB RAM and upgrade to 5850/5870 and you should be fine.
  16. Guest-16
    Guest-16 Guest
    He has 4GB of memory already, but I agree, the Q6600 needs an overclock, but his greatest limitation will be the 512MB of graphics memory.
  17. pizan
    pizan that's n00b-tastic
    25 Apr 2008
    Then how do you see our posts?
    You can get one hereor here
  18. nepenthes
    nepenthes What's a Dremel?
    15 Jan 2010
    *badum tish*
  19. pizan
    25 Apr 2008
    was more expecting a "wah wah waaaaahhhhh"
  20. stoff3r
    20 Nov 2006
    Thanks for replies guys, problem is, my q6600 started running hot a few weeks ago, and now I have it running stock and the temps are still in the 90's on load, any more OC'ing and it'll burn :/ And yes I did re-apply arctic silver goop! I guess I'll go for a gpu when that time comes.
Tags: Add Tags
