Hardware What Hardware Should I Buy? - October 2009
Discussion in 'Article Discussion' started by Tim S, 8 Oct 2009.
  1. mrbens
    mrbens What's a Dremel?
    15 Aug 2009
    Thanks for the tip. I ordered mine on Saturday and got an email back saying:
    New Estimated Stock Availability : 19/10/2009
    Not too long. :)
  2. smithgjb
    smithgjb What's a Dremel?
    12 Oct 2009
    Started to put an order together for the various components listed, only to be told that the Asus P6t Deluxe v2 is now obsolete! Agghh, finally made the commitment and decision to proceed, only to find the motherboard has gone!! Any recommendations in its place? The Asus P6t is still available it seems, would that be a good replacement? I'm not much of a gamer, thinking more of the video editing and future proofing. Thanks and regards
    Graham
  3. oatey4519
    oatey4519 can't be arsed...
    5 May 2009
  4. Hoffs
    Hoffs Seek
    25 Apr 2009
    A good read, cheers guys :)
  5. 00se7en
    00se7en Too many computers, too little time
    8 Sep 2009
    rpsgc - You were right. My Crucial SSD arrived today :) All it needs now is the new firmware and some TRIM-supporting Intel Storage Matrix drivers.
  6. Guest-16
    Guest-16 Guest
    Check the G.Skill 2000MHz Ripjaws at Novatech - plenty more overhead and are usually a good price. Failing that, try Scan or Ebuyer for OCZ/ Corsair.
  7. barrkel
    barrkel What's a Dremel?
    31 Jan 2007
    May be worth pointing out: Titan Fenrir is big enough in its default install (pushing air through heatsink to rear of case) that it blocks off one of the 6 memory slots on the Asus P6T v2 motherboard, especially as DDR3 is usually quite tall with heat spreader etc.
  8. srmans
    srmans What's a Dremel?
    8 Oct 2009
    Yes I noticed this too with my build using same HSF with an Asus P6T board. Although if you only get one set of three DIMMs then my M/B manual states to use the orange slots furthest away from the CPU socket first which are clear of the HSF. See M/B picture.
  9. barrkel
    31 Jan 2007
    Unfortunately, my day job is a software developer, and building our dev tree requires touching many GB of data. The more file cache I have available, the better; so 12GB it is.
    Provisionally, I have the fenrir around backwards, with the fan attached backwards, so it is sucking air through the heatsink and directly into the rear case fan. If heat becomes an issue long term, I'll replace it with something smaller.
    Unfortunately, I ran into a different problem, a bad 5870, so I have to wait to have that returned and replaced before this system gets into serious use.
  10. mrbens
    15 Aug 2009
    UPDATE: mine arrived today instead of 19/10/2009!
  11. 00se7en
    8 Sep 2009
    Good job - Dabs price now back up to over £270! Mine's installed and working, but awaiting Retail Windows 7 and a firmware update to enable TRIM.
  12. mrbens
    15 Aug 2009
    WOW! That was good timing! Price has gone from £219 to £274.85!
    All the rest of my bits I've ordered for my new build arrive tomorrow!
    Gonna be a busy weekend =)
  13. 00se7en
    8 Sep 2009
    £323 on the Crucial site now! That's over £100 more than I paid. Novatech seem to be among the cheapest at the moment. I should have ordered two!
  14. oatey4519
    5 May 2009
    no way...
    i was thinking of getting one this weekend for my new w7 install..
    will shop around
  15. Aracos
    Aracos What's a Dremel?
    11 Feb 2009
    Been challenged by my friend to beat a £350 compaq machine so I've been using this as a reference, anyway thought you'd be interested in hearing you can get a samsung F3 500GB for £36 here enjoy :)
  16. Trancer
    Trancer What's a Dremel?
    27 Oct 2009
    Hi guys,
    Always enjoy this section every month!
    Can you please consider looking at the Foxconn the Bloodrage GTI? As its about the same price as the Gigabyte GA-X58-UD3R and im wondering how it stacks up :)
  17. omgwtfbbqwallhax
    omgwtfbbqwallhax What's a Dremel?
    10 Nov 2009
    Was just looking at my case (CM HAF932) and i was thinking that if you mount the powersupply at the top of the case ( you will loose that big 200mm fan, but you can replace it with two 120mm fans if you mount the PSU at the top) you face fit that fourth graphics card in the case. Plus it has really nice airflow and a 200mm fan on the side to keep things cool :)
  18. omgwtfbbqwallhax
    10 Nov 2009
    you could fit* ... wasnt concentrating :D
Tags: Add Tags
