Peripherals What HDMI cable?
Discussion in 'Hardware' started by Kronos, 18 Jun 2013.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    As the title, I am looking for around 7m in length which is easy enough to find,CPC have them but there seems to be a choice. I am connecting HTPC to TV so am I looking for anything special or will anything pretty much do?
  2. GeorgeK
    18 Sep 2010
    Anything will do mate - as it's a digital signal the actual cable itself makes no difference. Don't fall for the 'gold plated super expensive cable' being better - it's just a con :thumb:
  3. phoenixck
    phoenixck What's a Dremel?
    7 Jan 2012
    Indeed cheapest one you can get, digital signals are either 1 or 0 . Word of warning make sure the build quality is good. Though this isn't dependent on price.
  4. mrbungle
    20 Sep 2004
    Id avoid "super super" cheap cables for a 7m run though tbh
  5. Kronos
    Kronos Multimodder
    6 Nov 2009
    Great guys. Thanks.
  6. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    I picked up a 10 metre hdmi cable from eBay and it's working fine no issues what soever and it cost me £7
  7. Taniniver
    Taniniver Minimodder
    24 Aug 2010
  8. jinq-sea
    15 Oct 2012
    The Cablesson IVUNA range are decent - well made cables and reasonable price :)
