What heatsink do you use?
Discussion in 'Hardware' started by Tim S, 11 Sep 2003.
  1. Phase Change (please state)
    1 vote(s)
    0.4%
  2. Waterblock (please state)
    18 vote(s)
    6.8%
  3. Alpha PAL series
    22 vote(s)
    8.3%
  4. Swiftech MCX462 series
    17 vote(s)
    6.4%
  5. Thermalright SLK series
    41 vote(s)
    15.4%
  6. Thermaltake (please state which)
    29 vote(s)
    10.9%
  7. Akasa series (please state)
    6 vote(s)
    2.3%
  8. Coolermaster series (please state)
    41 vote(s)
    15.4%
  9. Taisol series (760, etc)
    3 vote(s)
    1.1%
  10. Globalwin (CAK, CBK, FOP series, etc)
    0 vote(s)
    0.0%
  11. Other, Please state
    33 vote(s)
    12.4%
  12. Zalman series (please state)
    16 vote(s)
    6.0%
  13. Retail Heatsink/Fan combo
    30 vote(s)
    11.3%
  14. I don't, my CPU knows what I'll do to it if it misbehaves
    9 vote(s)
    3.4%
  1. mikey
    mikey What's a Dremel?
    29 Mar 2004
    coolmaster aero jet 7 lite... (new 2day :) workin well bit too noisey :( )
  2. skattrd
    skattrd What's a Dremel?
    22 Jul 2003
    Aerocool dp102 fitted with an 80mm aero blower and a 60mm taisol fan (I couldn't fit 2x80mm fans on it :( )
    Oh and an slk800a + silent papst on my AMD rig
  3. matrixx
    matrixx What's a Dremel?
    17 Jan 2004
    Currently using Gigabite GH-OCU21-VG 3D cooler Pro (Nice Blue Glow :D ) with 35 idl and 44-46 full load
  4. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    Cooler Master AERO7 Lite :rock:
    Cheers,
    Mike
  5. Dayains
    Dayains Notamodder
    18 Dec 2002
    same here...
    :thumb:
  6. Shepps
    Shepps Slacking off since 1986..
    5 May 2002
    i use my shuttle's ICE cooler thingie now :thumb:
  7. N4N01D
    N4N01D What's a Dremel?
    29 Apr 2004
    nay chance of you making the poll able to select multiple heatsinks ? i.e. for more than 1 pc :D
  8. Tim S
    Tim S OG
    8 Nov 2001
    I can't change the poll to be a multi choice poll now without creating a new poll.
    If people want me to add their second PC's cooling to the Poll, then please post the details of which category you're in, and I will add it manually. :)
  9. dr_crazy
    dr_crazy What's a Dremel?
    30 Apr 2003
    Well, i knew i had a Coolermaster i got when i ordered an upgrade kit from Komplett.co.uk. Just went there now to find out what i had:
    Cooler Master CPU-Fan Socket A/7/FCPGA
    DP5-6J31C-01, for 1,4GHz, and XP2400+
    My XP22000 is normally a 1.8ghz b4 i overclocked it, so i thinks im going to be investing in a new cooler ASAP!!!!!
  10. Atomic
    Atomic Gerwaff
    6 May 2002
    Ditto.
  11. Awoken
    Awoken Gazing at the stars
    3 Mar 2004
    I've got a totally silent Zalman CNPS7000A-AlCu, its waiting for a new fan (looking for a way to mount a 92mm Panaflo L1A instead of the Zalman as it'll push more air for the same amount of noise).
    I'm aware that I'm obsessed with silent computing and am receiving treatment :hip:
  12. unclean
    unclean SMP obsessive
    30 Dec 2003
    got me glacial tech HSFs
    - 2 x silent breeze 3 for my duallie (runs at 19db)
    - igloo 2520, runs at 25db
    - igloo 2520pro, runs at 35db normally.. but i err, kinda mounted a 55db delta on it :D 84CFM over the HSF = muchos cooling power.
  13. N4N01D
    29 Apr 2004
    oh ok didnt know it would wreak the whole poll, but i got a 462 - which i voted for and a slk900, could list all the others but not much point tbh
  14. dirtbiker
    dirtbiker What's a Dremel?
    24 Dec 2003
    I've got a Cooler Master Aero 7+
    It does the job quite nicely, can be really quiet or really cool with the supplied pot.
    Im happy with it, and it looks cool through my window. The downside is that its getting dusty :(
  15. pzr
    pzr Banned
    25 May 2004
    Coolermaster AERO7+
    running at lowest speed (1800rpm)
    using the supplied thermal compound
    system temp 31'c
    cpu temp 37'c (idle)
    cpu temp 40'c (full load after a hour)
    with front fan,rear fan, side fan, all running at 500rpm or something silly low /(antec trueblue 480w is controlling em)
  16. noCode
    noCode What's a Dremel?
    16 Oct 2003
    I have watercooling (Magnum 390 Socket A, not mounted at this time, but has been for long and will go back on after modding), that computer is now running on a modded Zalman 5100Cu. Another computer runs with a Thermalright SKL 800 with Enerman 80mm and third computer has a Spire Whisperrock.
  17. Der Me!$ter
    Der Me!$ter What's a Dremel?
    14 Sep 2002
    Zern MK7 CPU block, Aquacomputer Twinplex GPU block, Zern Server Radiator, Aquacomputer Airplex Evo 240, CoolCases resevoir, Eheim 1250, in the main rig. Shuttle ICE in the Shuttle. Some Coolermaster in the CarPC.
  18. Dodge
    Dodge What's a Dremel?
    10 Oct 2003
    coolermaster aero 7+
  19. TMM
    TMM Modder
    12 Jan 2004
    im soon going to get rid of my Aero7+ for a Zalman CPNS7000a-cu. I have silenced almost my whole case, but i still have the Aero whiring away at 2500rpm. the zalman (normal=25db) beats the Aero7(high(4000rpm)=40+db). sounds like a win-win situation :hip:
  20. daba
    daba What's a Dremel?
    28 Apr 2004
    I use SP-94 and have gotten temps like these!
    :D
