Open Source What is a good converter from AVI format to itunes format?
Discussion in 'Software' started by aliok798, 9 Jan 2010.
  1. aliok798
    aliok798 What's a Dremel?
    9 Jan 2010
    I haved downloaded a lot of videos and they are in AVI, I am searching for converters but all of them are for the mac.Anyone knows such a good converter?
  2. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    Try 'Badaboom' by Elemental Inc. its using the GPU to encode, I used it a lot of Time, friendly using and you save time. Its only work with Nvidia card, If you have a ATI take Avivo
  3. azzybish
    azzybish What's a Dremel?
    23 Apr 2009
    The new versions of Handbrake did some wonderful conversion for me, quality was superb on the iphone. Just download it, select the source file and click the ipod/iphone preset and itll set it up nicely.
  4. Edge102030
    Edge102030 Son, i am disappoint.
    21 Aug 2009
    QFT, handbrake all the way.
  5. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    i have just downloaded 'jodix free ipod video converter' its quick and simple to use i have just convertered 2 avi files and its very quick
  6. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    If it's to put on your iPod/iPhone, try iPodRobot (the Video Converter is free)
  7. Pookeyhead
    30 Jan 2004
    +1 for Handbrake!
  8. wyx087
    15 Aug 2007
    or kvip just drag and drop, everything is pre configured and never failed me so far.
  9. Byron C
    Byron C Official Necromancer
    12 Apr 2002
    +1 more to Handbrake - simple and uncomplicated interface. It doesn't need you to poke around with bitrate settings to produce a good quality output.
  10. flame696
    15 May 2009
    Also there is videora which again is free
