Graphics What is AGP fastwrite?
Discussion in 'Hardware' started by couzo, 29 Jun 2002.
  1. couzo
    couzo What's a Dremel?
    26 Apr 2002
    I have been looking through my bios and saw a thing called AGP fastwrite what does this do and will it increase performance???
    Also how do you engage FSAA? As I have a brand new gf4 4600 and want to put it through its paces!!
  2. rK@NE
    rK@NE Rover's gonna get it...
    20 Dec 2001
    Allows data to be sent directly from the corelogic (i.e. chipset) to the AGP master (graphics chip) instead of keeping a copy in system memory and making the AGP master fetch it. Enabled it for best performance.
    You'll find your FSAA settings in display properties>settings>advanced
  3. TrumpetSteve
    TrumpetSteve What's a Dremel?
    21 Feb 2002
    I still dont get the Aperture Size thing, If I have a 128MB ATI Radeon 8500LE, what should it be set at?
  4. Morphine
    Morphine weeee!
    23 Feb 2002
    64 i believe
  5. Lucifer
    Lucifer What's a Dremel?
    18 Nov 2001
    your AGP aperture wants to be half your system memory, so since i have 512mb RAM my AGP aperture is 256mb
  6. Guest-16
    Guest-16 Guest
    Or 128 - this is the most common config IMO, some people have found that 256 gives a lower or no better performace then 128. But defo no lower then that.
