Other What Is Draft Printer Setting?
Discussion in 'Software' started by nathanplane, 14 Oct 2009.
  1. nathanplane
    nathanplane Banned
    7 Oct 2009
    Set the printer setting as draft printer setting reduce the ink usage. so I would like to what is draft printer setting. how can I set it up?
    Help please
  2. Brooxy
    Brooxy Loser of the Game
    20 Apr 2006
    From what I remember it prints at a lower DPI, therefore saving ink.
    It's dependant on what OS you are using for the setup. Think on mine I do it in printer preferences, but not 100%
  3. outlawaol
    outlawaol Geeked since 1982
    18 Jul 2007
    I assume you want to know what it does. It does reduce ink usage. Once set you dont need to do it again. To set go to control panel > Printers > right click over printer > settings > quality. Be aware it may be called something else, but it should be along those lines.
    Also this should be in the hardware forum. :)
  4. nathanplane
    nathanplane Banned
    7 Oct 2009
    I have done it. Thanks for your feedback. Thread is closed.
  5. capnPedro
    11 Apr 2007
    Or is it?
    gnutonian likes this.
  6. nathanplane
    nathanplane Banned
    7 Oct 2009
    sorry for reposting, but I want to make aware people from fact...
    I have used my printer in draft mode for a week. it saves ink effectively. but it is only for testing. You can only use while you print less importance paper.
    Thanks.
