what is te best hs for socket939?
Discussion in 'Hardware' started by pillow, 9 Nov 2004.
  1. pillow
    pillow What's a Dremel?
    16 Aug 2004
    i would like to know what the best hs for socket 939 is? i will be getting a 3200+ and while be playing games and overclocking, so what is the best hs because i have searched around but i am stuck :confused: ?
  2. JuMpErFLY
    JuMpErFLY Minimodder
    13 Mar 2003
    thermalright XP-120
    Or the SLK-948U below it if you're on a budget
    [edit]xp-120 is very big so check it will fit[/edit]
