Windows What is the best antivirus for win xp sp2
Discussion in 'Software' started by tigra, 23 Oct 2004.
  1. tigra
    tigra What's a Dremel?
    23 Oct 2004
    I have a computer with win xp sp2.
    I tried norton and AVG anit virus.
    They allmost let all virusses pass into my pc.
    what is the best anti virus for win xp sp2 you think?? :blah:
  2. Ryu_ookami
    Ryu_ookami I write therefore I suffer.
    11 Mar 2004
    i've got win xp sp2, avg and sygate and i've yet to get a virus i suggest you update to a decent firewall and keep avg upto date.
  3. sheardjr
    sheardjr Minimodder
    7 May 2003
  4. Atomic
    Atomic Gerwaff
    6 May 2002
    I use McAfee Viruscan.
    Not had any problems with viruses since Ive been using it. Nicely intergrates with SP2 and bitches when its been shutdown/definitions out of date.
  5. cpemma
    cpemma Ecky thump
    27 Nov 2001
  6. darkhunter
    darkhunter What's a Dremel?
    13 Apr 2004
    holy crap thats bad i gotta do something where do u get nav and if so how much is it
  7. aaronrkelly
    aaronrkelly What's a Dremel?
    1 Jan 2004
    I use Avast (www.avast.com) it katches alot of stuff Norton lets through and is way less memory intensive. Its free but you do have to register it every 14 months or so.
    No matter what AV program you use you should get a second opinion periodically. We know that running two AV programs is a bad plan so I suggest and use Trendmicro's Housecall - its an online AV scanner that works with IE. Works great, fairly quick and is also free........give it a shot.
