Other What is the fastest DVD/BD rom drive for installing games?
Discussion in 'Hardware' started by Guest-44432, 31 Mar 2011.
  1. Guest-44432
    Guest-44432 Guest
    I want the fastest DVD/BD rom drive for installing games, I'm not fussed about noise.
    At the moment I own a LiteON iHAS524 A DVD drive..and it so slow for installing from disc.
    What do you guys recommend?
    Also Bit-tech, I would like to see a review of todays DVD/BD rom drives, in CustomPC soon.:D
    Cheers,
    Simon.
  2. sonicgroove
    sonicgroove Radical Atheist
    16 Mar 2011
    you have pretty much the fastest drive already. there are 52x drives, but you wouldn't notice any difference on the read speed as the DVD discs rarely spin up to full speed anyway.
    I would imagine you notice the tardyness of the cd reading speeds because the rest of your rig is almost instantaneous and is built with that in mind.
    Use steam and the like for downloading games and you'll see a massive difference to the installation speed.
  3. Guest-44432
    Guest-44432 Guest
    I know what your saying, but it is not the answer I'm looking for...But thanks for the reply:thumb:
    I have had a HP DVD rom drive in the past and it installed games veryfast, it was noisy..but it took half the time to install a game compared to my Liteon.
    My liteon drive installs games at about 10MB/Sec...
  4. Fingers66
    Fingers66 Kiwi in London
    30 Apr 2010
    I'm assuming that your A/V software isn't scanning the DVD drive during installations? Try disabling it for one installation and see if it makes a difference?
    Doesn't it also depend on the amount of buffer memory on the optical drive as well?
  5. Guest-44432
    Guest-44432 Guest
    I don't think so? I'm using MSE.
  6. Fingers66
    30 Apr 2010
  7. gilljoy
    gilljoy Minimodder
    14 Nov 2010
    Same situation as you man, my dvd drive is rediciously slow and loud :(,
    Gona buy myself a BD-RW drive soon I think
  8. Guest-44432
    Guest-44432 Guest
