Either thats not a IDE port, or thats not a IDE cable. Sorry about the unclear pic. Any ideas, the cable has 52 pins (i guess its not an IDE cable then) The mobo has 40 -1 pins
Right, It dosent fit in the floppy port either so ill go with scsi unless there are any other ideas, or should I say IDEas. EDIT: atualy I dont think it is a scsi but I may be wrong
Those are IDE ports, as for the cable its certainly not IDE or floppy. Don't think its SCSI either. Can you post a close up pic of the connector itself? Also where did you find the cable?
But then he might not have so you can't say its definetly scsi If he did miscount then yes it probably is 52pin scsi...
Ok sorry, I did miss count, 50 pins. I counted half and doubled it, must of counted one twice. Its a scsi 50 then. Thanks for all the help.
