Linux What is this Linux thing?
Discussion in 'Software' started by Glider, 27 Jul 2006.
  1. Fophillips
    Fophillips What's a Dremel?
    9 Oct 2006
    The only way it can be, by not being free.
  2. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
  3. Fophillips
    9 Oct 2006
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Losing the window controls is a sure sign of not having a theme for Compiz/Beryl installed.
    Look for "emerald" in your repository. It's the window decorator for Compiz Fusion.
    Then find yourself a theme you like at Gnome-Look or KDE-Look.
  5. Woodstock
    Woodstock So Say We All
    10 Sep 2006
    just had a look at that unixtoolbox you mentioned, and i have to say its a great lil resource, but i gave a mate the link to the guide as hes a bit cuirious about linux (maybe i played a part there) and he said the screenshot links you have placed no longer have the images stored on the server
  6. Glider
    Glider /dev/null
    2 Aug 2005
    Well, the server glitched last saturday, which made it unavailable. It's fixed already and the images are showing to me tough.
  7. DougEdey
    5 Jul 2005
    I've had people say to me (and me myself) that they miss Winamp, whereas I was looking for a very lightweight media player, but audacious doesn't have a library.
    So I found http://ubuntuforums.org/showthread.php?t=680736 which is for Ubuntu but can be easily transferred to other distros.
  8. UncertainGod
    UncertainGod Minimodder
    18 Oct 2007
    I did miss winAMP for quite some time but I could never like Audacious as it has some of the weirdest bugs (playlist window 'running away' from the mouse pointer, etc) in the end I've found happiness with a slightly tweaked version of Consonance. It was built by a guy in the Archlinux community and very light and built with gtk+ so it's perfect for light DE's, only change I made was to add audioscrobbler support (still buggy but I've only been playing with it for a couple of days).
  9. Glider
    Glider /dev/null
    2 Aug 2005
    Mostly I play media from my FS, through VLC with the ncurses (terminal) interface... That or AmaroK.
  10. Fophillips
    9 Oct 2006
    I did use moc but I found it to be a little lacking in features, now I use AmaroK and couldn’t be happier :)
  11. Woodstock
    10 Sep 2006
    i normally use amarok but im giving decibel a try, if i can get it to run
  12. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    I use amarok but if winamp is you thing try xmms, it supposed to use winamps skins.
  13. Glider
    Glider /dev/null
    2 Aug 2005
    Added some tags, and a couple of updates... I should really do a big one...
    Damn you job!
  14. Rocket733
    Rocket733 Austerity - It's the only way
    27 Dec 2003
    I just got ubuntu up and running (wanted to use my wireless apple keyboard without issues) and found this guide for installing from a usb drive to be particularly handy.
  15. Rum&Coke
    Rum&Coke What's a Dremel?
    23 Apr 2007
    Just installed ubuntu to give it a whirl, I tried Debian years back but lack of internet connection kind of hampered the whole process. Everything seems to be running pretty smoothly but I've got a problem with getting sound from youtube videos. Im assuming its the flash plugin, i've tried a couple different fixes but nothings worked, or atleast nothing that I understand yet. Im working off Firefox 3.0, a couple things have suggested editing firefoxrc but I honestly can't find it anywhere. Any tips?
    edit: Fixed! killall pulseaudio . Is there any reason to not remove pulse audio?
  16. DougEdey
    5 Jul 2005
    Because the dependancy tree is locked with it. They really need to kill off pulseaudio, even the guy who makes it says it's not ready yet
  17. Rum&Coke
    23 Apr 2007
    Im trying to get multiple audio streams working, I installed esound but no options in the sound config?
    edit:Fixed again but in a kind of round about way. using different audio packages for browser and music player. Got EsounD appearing in sound preference but wouldn't work.
  18. Aterius Gmork
    Aterius Gmork smell the ashes
    25 Sep 2007
    Even though it is not Linux only I really believe XBMC should be on this list. It is the best Media Center software I have used up to now. Simple, easy to use and yet extremely powerful, plus it looks good. And it works on Linux, right. ;)
  19. Cjshuck
    Cjshuck What's a Dremel?
    20 Dec 2008
    So what things would I not be able to have if I decided to get Linux?
  20. Cjshuck
    20 Dec 2008
    As in what things on Windows would no longer be available. (Sorry I didn't explain it very well)
