Linux What is wrong with my FTP server?
Discussion in 'Software' started by Deviate, 28 Jan 2004.
  1. Deviate
    Deviate What's a Dremel?
    3 Jun 2002
    I'm not sure if this should be in here or the Linux/Open Source forum. But I figured I'd try in here first. I have a box at home running Debian Linux and I have ProFTPd running on that box. It is behind a Linksys BEFSR41 dsl router.
    When I'm on my Windows2K box at home (also behind the router) I can connect to the FTP on debian box using both the internal and external ip addresses. When I try to get to the server from work I get a popup message from Internet Explorer telling me something about my proxy not allowing me to view ftp servers blah blah. I figure that is just something they have set up here on our network. I have also tried with FTPExplorer. It says connection established then error connecting to... I also tried it in BlazeFTP and it just keeps timing out. But that is FTPExplorer and BlazFTP here at work again. When I try it from somewhere else, say a friend's machine, I get page cannot be displayed.
    I'm pretty sure that I have all of the ports open correctly on my router to allow ftp. I have port 21 for ftp and 50000 - 50100 for ftp-pasv opened and forwarded to the debian machine. When I look in the logs on the debian box I can see where ftpuser attempts to connect. It says they connected. Then it says they disconnected. :confused:
    So what else can I look at?
  2. Will
    Will Beware the judderman...
    16 Jun 2001
    RTT@Will's account:
    That would be something to do with the proxy at your works connection. Tried any other FTPs to make sure? ftp://ftp.slackware.com
  3. Deviate
    3 Jun 2002
    I just tried the slackware ftp and I can get to it fine. The message I get about the proxy here at work says that everything will be read only because the proxy will not allow anything else. But I can get to slackware and browse around and all. So I'm guessing it's something in my FTP configuration? But then why can I view it from my machine at home? Maybe I'll have to check my router again too. Make sure everything is working there.
  4. RTT
    RTT #parp
    12 Mar 2001
    Try running it in the DMZ on your router? Maybe it needs more than just port 21. Sometimes 23 and 21 (or one of the two) I think have to be opened.
  5. BlackTower
    BlackTower What's a Dremel?
    1 Aug 2003
    20 and 21 is standard. 23 is telnet iirc.
  6. RTT
    RTT #parp
    12 Mar 2001
    That was it :blush: Knew it was around there somewhere... :blah:
  7. Deviate
    3 Jun 2002
    Interesting. I went home and tried to connect to the FTP using http://www.net2ftp.com/ just to test it out. And I connect fine. So....I guess it's working? I didn't change anything. Maybe I'll set up everything at dyndns and see what happens. Thanks for the help guys and for moving the thread. ;)
  8. RTT
    RTT #parp
    12 Mar 2001
    You are using the correct mode aren't you? PASV is what you need to use from your client :)
  9. Deviate
    3 Jun 2002
    I'm trying PASV from work. I get timeouts...so I'm still thinking that it's a bust from work. But from my friend's house, he only has Internet Explorer, and it is probably using port mode. I'll check that. If I wanted it to be able to use port mode, would I have to setup something different on my FTP config?
  10. Deviate
    3 Jun 2002
    I think I have determined the problem. Firstly, I think it's because I'm trying to use ProFTPd. If I had used WU-ftp or something else, I might not even have this problem, but I don't know that for sure. Anyway, turns out that ProFTPd (at least) needs me to do a few other things and install a few more packages because my router uses NAT.
    Essentially, I have to manually (via ip-masquerade) define the ip address (or domain name) that the ftp server is masquerading as. And then I also have to define the ports that I will be using for PASV mode. Finally I will have to explicitly link (not sure how else to say it) the linux box's ip to the masquerading ip and then define the ftp ports.
    Sounds like a lot of fiddling, but I don't think it will be that bad. I'll tackle it when I get home tonite and see what I can do. :thumb:
