Peripherals What is your favorite mouse?
Discussion in 'Hardware' started by N17 dizzi, 13 Feb 2012.
  1. dogknees
    dogknees Minimodder
    27 Dec 2008
    Logitech MX Air, but not if its for gaming. For a media PC it replaces a remote pretty effectively and works well as a normal mouse on the desk.
    It was expensive, and the battery isn't replaceable (it actually is, but takes a bit of work and voids the warranty), but it's still going strong and holding a charge for a couple of weeks after 4 years use.
    Plus it looks like a tiny spaceship landed on my desk, which can only be a good thing.
  2. TheKrumpet
    TheKrumpet Once more, into the breach!
    18 Oct 2011
    I recently picked up the Logitech G500 and I'm really enjoying it so far. The shape is basically the same as the Logitech MX518 (my previous favourite mouse), really comfortable, very smooth & accurate. The scroll wheel is a little loose, but once you get used to it it's a very fine mouse.
  3. GoodBytes
    20 Jan 2007
    Trust me, a built-in Lithium-ion battery is FAR better than a AA battery.
  4. Arghnews
    Arghnews What's a Dremel?
    6 Jul 2011
    Razer Krait, although sadly I can't find any anywhere ! :(
  5. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Best I have used are razer deathadder, logitech g9, mx518, g5, and my new coolermaster sentinel
    sent from HTC Sensation
  6. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Length 119mm width 77mm height 40mm... bloody comfy for me but I have small hands. <Insert penis joke here>
    I love the M60. The finished aluminum body is stunning. I haven't tried the software yet so I can't comment on that.
    I feel like applying for a job at the Corsair fanclub. Everything I have got from them is quality.
    The only thing the G500 did better is the middle switch that free'd the scroll wheel. But this has a sniper button which I haven't had before, maybe I will actually try being a scout in BF3 now!
  7. maestro0428
    maestro0428 Master Modder
    24 Jun 2010
    mx518. I am on my second one. Love it, but I do wish it was cordless sometimes.
  8. LennyRhys
    LennyRhys Oink!
    16 May 2011
    G9/G9x - love the shape, feel and weight. I've been using an MX518 for the last year or so but I really miss the G9 and it'll be my next mouse when the time comes.
  9. Fanatic
    Fanatic Monimidder
    4 Jun 2010
    I've just replaced my 6 year old razer diamondback after left microswitch failed and got a logi G700. Ordered some omnicron microswitches to fix the razer too in case I didn't get on with the logi but I'm growing to like it.
    I have tried 5 different mice over the years but none as comfortable as the diamondback. Kone too big, lachesis just felt wrong etc. etc.
    G700 is taking a bit of getting used to but is becoming more natural now. Wirefree for general use but wire it for gaming, feels a tiny bit sharper wired. Got it for 50 quid too which helps!
    Sent from my HTC Desire using Tapatalk
  10. Grimloon
    Grimloon What's a Dremel?
    4 Sep 2008
    My Diamondback Magma edition is still going strong, just moved to a second PC. I honestly don't know how old it is, I bought it when they had just been released.
    The current one is preferable though - Razer Imperator. I had a bit of a stretch for the front thumb button on the Diamondback so being able to slide them back so my thumb sits on the divide between the two is great. Add on top of that how light it is and it's definitely my favourite.
  11. ninjaplease
    ninjaplease I don't know what I'm doing
    11 Jan 2012
    I bought a gigabyte m6800, it's a piece of ish but I couldn't afford anything else at that time. One thing I will say though which may aid this thread is that today I covered it in di-noc which, for those who don't know, is a self-adhesive vinyl that looks and feels like carbon fibre. Best decision ever, it has so much more $W@G now than it used to.
  12. leslie
    leslie Just me!
    19 May 2009
    Logitech Revolution.
    Absolutely perfect except two things, the charging contacts should have been recessed instead of dragging on a dirty mousepad and the dpi needed to be higher. Otherwise, it was the perfect mouse. I have a bluetooth version for the laptop (not the mini). :)
    The G700 is also great.
    It lacks the build quality and auto scroll, but works fantastic. The replaceable battery has good and bad points, it doesn't last long (changing to a 2700mah helps), on the other hand, it's replaceable, so you never are down. Also, I don't trust the micro usb charging port to last. I think the MX Rev. had a better shape too.
    The MX Performance was a cheapened MX Revolution. The build quality took a hit, the shape changed, and in heated shooting, the left mouse button would just stop working for 2 seconds.
  13. Fanatic
    Fanatic Monimidder
    4 Jun 2010
    I bought 4 x Eneloop 2000mah complete with charger for 11.49 quid delivered off Amazon. Every 2 batteries I just charge them up again and keep cycling them.
    My Razer Diamondback lasted 6 years till the left switch went a few weeks ago, but that has been through some serious usage in its lifetime. Great mouse.
  14. Unicorn
    25 Jul 2006
    My 'extension of my hand' Logitech G5. Not the best mouse in the world, and not without it's flaws, but I fell in love with it years ago and couldn't bring myself to change it now.
    Btw dizzi, do you still have the faulty G500? Can haz? (can fix ;))
    Thread related: since a lot of people are mentioning faulty mice in this thread, I'll offer my services to get your digital rodents in working order again. I just bought 100 microswitches last week for mouse repairs :)
  15. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Don't suppose you could work out why buttons on mine stop working if I tighten the casing too much? It doesn't even directly contact the switches, it just stops working. (seriously. If I do the screws more than semi-tight (Not even finger tight) half the buttons stop responding. They still click and stuff, just don't do anything.)
    Then again, this fault has been there for three years, and I only opened it up to fix it two years ago. Haven't needed to since. Probably not worth fixing it for the price I paid for it...
  16. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    It's not that much smaller than my Sidewinder then... I may have to get one...
  17. russ555
    russ555 What's a Dremel?
    24 Apr 2009
    The CM storm inferno isn't bad. When cleaning it though be careful not to use anything rough otherwise it will ruin the coating on it and make it feel all bumpy and horrible.
  18. dogknees
    dogknees Minimodder
    27 Dec 2008
    Agree. I was a bit doubtful when I got it, but it's proven itself. Same with the DiNovo Edge. I still get 45-50 days on a charge.
    :thumb:
  19. Fantus
    Fantus Nothing to see here...
    25 Jun 2010
    Flexing the PCB and breaking a contact, maybe? That'd be my guess.
  20. xaser04
    xaser04 Ba Ba Ba BANANA!
    27 Jun 2008
    On my desktop I run a Cyborg R.A.T 3 as I found it the best ergonomically for me after trying out most of the models in my local PC World store (one of the things they can actually be useful for).
    I still have an irrational love for the £6 Wireless Optical Trust mouse I got from Tesco about 5 years ago. Technically compared to my RAT it is terrible but ergonimcally it is perfect. Sadly its wirless dongle has started to play up recently so it will soon have to go :(
