A Volts-wagon! Anyway. Now I have your attention. I want to talk about the new upcoming PSUs from Antec. They are called the EA Gold Pro. As you can guess they are 80 Plus Gold rated, they are semi modular and to boot are made by Seasonic, so are some of the best in terms of quality and performance. We are offering a lovely 7 year warranty for peace of mind too. There will be a 550w, a 650w and a 750w version. With the exception of the 24 pin MBU connector all other cables will be the excellent flat style for easy cable management. Here are the pics of the unit. Below is the 750w spec data... The only change other than the wattage is the 650w and 550w has 1 x 4+4pin only and 6 x sata connectors The 550w also only has 2 x PCI-E connectors.
Odd. It seems like the text in OP is specified as black, as opposed to unspecified so it changes with the theme.
Yes the text has been set to a specific colour (most likely due to it being copied from a press release ) Please remove the formatting from the text so users of the glorious dark theme can correctly read it.
